Author Topic: Autotech HPFP failure  (Read 44184 times)
Offline KRL
  • -Receive: 29
Re: Autotech HPFP failure
« Reply #30 on: December 30, 2010, 11:55:32 pm »
You cannot change the seal AFAIK, it certainly isn't listed by VAG, maybe you could source it 3rd party or from Hitachi but I wouldn't hold out much hope.
APR do change the seal.
Bummer if the seals are hard to come by :(
I know APR change the seal but I was wondering they upgrade it somehow or if the just replace it with another OEM one.
Offline muckipup
  • -Receive: 25
« Reply #31 on: December 31, 2010, 12:03:07 am »
Sorry to hear about this problem muckipup.
I would like to understand two things:
1.  This link from JKM you posted (http://www.jkm.org.uk/performance/Misc/Misc_Performance_pictures/APR%20Pump/tech/pumpimages/Visio3_big.jpg) seems to imply that stepped pistons will put more pressure on the the fuel pump seals than a non stepped piston.  Is this correct?
2.  I would like some more information on how often the seals have been failing and weather APR does upgrade the seal or use the OEM one.  I would like to know if I should change my seal after x number of miles?
Those are very fair questions KRL. There are a few more links to HPFPs, I only picked one to highlight a hypothesis. It is only a hypothesis which kinda makes sense to me in a non-expert way. I can't speak for JKM and I don't think they will speak for themselves (in fairness, I think they voted with their feet as this is a sensitive issue as you know)
Again, I don't know of the failure rate of OEM seals, the back/return pressure of after-market internals running higher rail pressures and I can't speak for APRs engineering methods. I reckon it would need some kind of formal study rather than a forum to be accurate on that one. All I can do is report my experience in a non-judgemental way and say 'sniff the dipstick' again and again
Offline muckipup
  • -Receive: 25
« Reply #32 on: December 31, 2010, 12:06:38 am »
Jeeeziz, just read my own post back and was knocked sideways about what a non-commital pussy I was  :ashamed: I'll get another large gin and be gone. Peace be with you  :drinking:
Offline KRL
  • -Receive: 29
« Reply #33 on: January 02, 2011, 03:14:46 pm »
Did you do any logs of your car while the problem was active?  Just wondering if this can be spotted through logging - for example maybe the rail pressure would not be able to meet requested if fuel is leaking through the seal.
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #34 on: January 02, 2011, 03:39:49 pm »
No the only way to see the problem is if fuel gets in the oil.
The problem is when the piston is on the return stroke. So it won't show a drop in rail pressure.
Offline yin
  • -Given: 77
« Reply #35 on: January 02, 2011, 04:08:45 pm »
Don't know if this is true but have been told Pump seal failure is what killed the engine on Revo's  K1
Offline Janner_Sy
  • -Receive: 113
« Reply #36 on: January 02, 2011, 04:35:06 pm »
i wasnt aware of a failure on REVOs K1 demo car????
In all fairness they would always blame a hardware fault and not software
« Last Edit: January 02, 2011, 04:42:41 pm by Janner_Sy »
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #37 on: January 02, 2011, 04:41:35 pm »
There is NEVER a fault with the software. Its always a boost leak :laugh:
Offline Janner_Sy
  • -Receive: 113
« Reply #38 on: January 02, 2011, 04:44:49 pm »
I wander how this was kept out of the forums for so long.  Are they running the K1 with a new engine now or have they handed it off to some one else
Offline RobH
  • Revo stg 2+
« Reply #39 on: January 02, 2011, 04:49:13 pm »
I have herd of a couple of these now, Revo's K1 been one of them and an S3 apperently so an APR pump might be on the cards, also headgaskets seem to have gone on a couple of cars all needing new engines :scared:
Talking to INA the headgasket is above industry standards and its the bolts which look a bit weak so maybe ARP bolts might not be a bad idea for longevity. I think there around 200 USD shipped to anywhere in the UK.
Maybe stage 2+ is starting to catch up on a couple of engines.
Off to go smell the dipstick now.
Offline Janner_Sy
  • -Receive: 113
« Reply #40 on: January 02, 2011, 04:53:31 pm »
in all fairness, Al (DJhorice) has been saying this for a while and also knows of a few engines going t!ts up
Offline djhorace
« Reply #41 on: January 02, 2011, 05:32:25 pm »
Yep, I have, and one of the reasons my new car is still standard for now.
I am taking my fuel pump with KMD internals to Texas in the near future to be APR upgraded though as may well be tempted to up power a little this year once I have got past any teething issues on the car. I would also be looking to check strength of head gasket and bolts too if I go back to S2+.
Offline KRL
  • -Receive: 29
« Reply #42 on: January 02, 2011, 07:06:00 pm »
I think I will start doing some oil analysis every other oil change to catch problems like this.  A quick google found this company:
http://www.theoillab.co.uk/
A report costs £26.95.  Think this could be well worth it in the long run if you weigh it up against the costs of potential failure.
Offline Janner_Sy
  • -Receive: 113
« Reply #43 on: January 02, 2011, 07:11:19 pm »
thats a good idea.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #44 on: January 02, 2011, 09:07:19 pm »
We use a similar thing at work - Spectrographic oil analysis
Stu...
