Author Topic: Parrot CK3000 - what else is needed?  (Read 1594 times)
Offline SeanyK
  • -Given: 35
« on: December 30, 2010, 10:35:37 pm »
Hey folks,
I am going to buy a Parrot CK3000 handsfree kit, I don't need all the bells and whistles, I don't even want it in sight, it's the most basic model, I have bought a Parrot Multican adaptor from Darren so I can use the MFSW phone button to make/answer calls with.
Anyway, I still need the CK3000 Evo, they are about £60, the question is, do I need any other adaptors? ie ISO plug adaptors etc? It will be fitted with a RCD510 so I will be pretty much using OE connectors all the way.
Thanks in advance,
Sean
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=hf6n567g8i2hpcbsgo5lh8rp30&/topic,19740.0.html
Re: Parrot CK3000 - what else is needed?
« Reply #1 on: December 30, 2010, 10:42:43 pm »
IIRC... youll need an ISO - Quad lock adapter! (i can remember looking behind my MFD2 and thinking F88k thats a mess)
Offline mortygttdi
  • -Receive: 146
« Reply #2 on: December 30, 2010, 11:58:54 pm »
I'm sure the adaptors are in with the parrot kit and the multican you just connect them together and plug the other side into the headunit???
Darren
« Reply #3 on: December 31, 2010, 12:07:36 am »
The parrot kits just give the standard ISO cables (1 power and 1 audio)
Offline Lyons
  • -Given: 18
« Reply #4 on: December 31, 2010, 10:11:25 am »
An SOT lead is definitely required, Parrots just cone with the ISO wiring loom.
