Author Topic: Tips for stopping the number plate backing coming away?  (Read 1144 times)
Offline bodger00
  • -Receive: 20
  • A wish called Zonda
« on: January 02, 2011, 05:57:31 pm »
This is a pet hate of mine that every year the number plate backing seems to start to separate. The number plate then looks poor and needs replacing. Does anyone seal them somehow? Perhaps on the edge to stop water ingress?
Offline 182_blue
  • -Receive: 54
Re: Tips for stopping the number plate backing coming away?
« Reply #1 on: January 02, 2011, 07:29:38 pm »
Most problem i see come from the drilled holes so i guess sticking them on helps, also when you buy them rub the backs to ensure they are stuck down correctly,  other than that then i would just change them over for new one every so often, they are quite cheap to buy now
Offline bodger00
  • -Receive: 20
« Reply #2 on: January 03, 2011, 10:17:08 am »
Thanks. I stick them on with the adhesive pads so the waters obviously getting in from the sides. I might try a thin layer of silicone sealant around the edge to see if that helps. :driver:
Offline chip20
  • -Given: 35
    • http://absolutevaletinguk.co.uk/
« Reply #3 on: January 03, 2011, 01:23:16 pm »
Drill the plate from the back not the front  :happy2:
