Author Topic: SWCM removal.  (Read 1197 times)
h4rdy
SWCM removal.
« on: January 03, 2011, 03:17:12 pm »
I tried everything including the info on here after a search.
But I don't like giving up but I had to.
Looks like my VAG mate is getting some business in the week.
I unclipped at back and found the secret hole but still would not budge.
Now I have a dash lit up like a Christmas tree too with Traction Light, Tyre Pressure, and the Steering wheel light.
On a positive the MFSW works without coding but I couldn't fit my cruise!
No more days left now!
Offline apollo13
  • -Receive: 47
Re: SWCM removal.
« Reply #1 on: January 03, 2011, 03:25:52 pm »
If you mfsw works ok then that module should be compatible for the cruise too....it probably needs coding.
There is a clip in the middle of the module that needs releasing with a long 3-4mm drill bit or long thin screwdriver or even a skewer!!
If you look at the one your swapping it with it'll make it clearer  :happy2:
