Author Topic: Rear brake caliper piston wind back?  (Read 13190 times)
Offline dnLcal
« on: January 05, 2011, 06:26:09 pm »
Hi,
Not sure but 99% sure it will still apply with our brake calipers but...
I have replaced brake pads and discs on friends and families VWs over the past few years.
And on my step musms 54plate bora TDI and my dads 03 plate caravelle TDI i have experienced a problem while trying to wind the piston back into the caliper.
I use needle nose pliers (and has always been fine) but with the two above mentioned cars the piston would not wind back in, if you rotate it anticlockwise it will come out further.
After much swearing and rotating it did go back in but 90% of my time was spent rotating the piston and nothing happening.
I had the brake resivoir open this didnt seem to help. but once it did start going back in it was a dream.
Any help on helping me understand this issue would be greatly appreciated!
Cal
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Rear brake caliper piston wind back?
« Reply #1 on: January 05, 2011, 06:30:10 pm »
I did some on an Octavia vRS last week using a Draper windback tool - No problems.
Stu...
Offline QD MBE
  • -Receive: 102
« Reply #2 on: January 05, 2011, 06:36:58 pm »
I have found that you need to apply a little pressure to the piston, as you rotate it/wind it back.
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #3 on: January 05, 2011, 06:42:31 pm »
This is what I used -
http://www.amazon.co.uk/Draper-33606-Caliper-Wind-Back/dp/B0001K9SSO
As QD says it will apply pressure as it winds
Stu...
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
« Reply #4 on: January 05, 2011, 06:43:57 pm »
Or just buy a halfrauds wind back tool for 9.99 pushes as it winds...
Used one for years before having to buy one with multiple attachments for RS4 rears etc etc
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #5 on: January 05, 2011, 06:45:43 pm »
I agree, there are lots of them about for around a tenner.  :happy2:
Stu...
Offline dnLcal
« Reply #6 on: January 05, 2011, 06:53:45 pm »
I'm definatly going to invest in a wind back tool, but just confused at to why it wouldnt wind back, sometimes i was using pressure, myabe not enough as it was quite akward with the long nose pliers!
cheers for the replys
Cal
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #7 on: January 05, 2011, 08:02:16 pm »
Ahem WE did some on an Octavia vRS last week  :booty: :notworthy:
Offline micaerin
  • -Given: 19
« Reply #8 on: January 12, 2011, 11:22:26 pm »
do you have a link for this, i cant seem to find it?
2007 GTI DSG, Xenon's, Armrest 6 Disc ,Rear Parking Sensors,Sunroof,Lux Pack,Cruise,Electric drivers seat,MFSW,RNS 510,Miltek Cat Back.
Offline paulgrant
« Reply #9 on: January 19, 2011, 10:48:44 am »
i got mine from halfords does a great job
