Author Topic: HELP - Select Switch Software - does anyone have it to upload?  (Read 3238 times)
Offline berg
  • -Given: 49
  • -Receive: 38
« on: January 05, 2011, 07:22:06 pm »
Hello chaps, bought a now obsolete Select Switch off h4rdy when got Revo as dont really think I will need SPS.
Now both Revo dealers I have seen have not been too helpful in putting my settings onto the switch and h4rdy's too aggressive settings for me are still on it.
Went to Revo site to d/l software as Rob at Revo suggested I could do this.
However, it recognises that the switch is not an SPS and wont let me d/l the software.
So basically I need someone to send me the old software so I can finally use the switch, failing which will have to speak to Revo and maybe post it to them and ask them to sort this out for me.
any help much appreciated (unless you wanna by switch back J? :wink:)
  • -Receive: 291
Re: HELP - Select Switch Software - does anyone have it to upload?
« Reply #1 on: January 06, 2011, 03:44:36 am »
Havd you tried contacting Revo HQ rather than relying on dealers?
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #2 on: January 08, 2011, 06:44:16 pm »
nope that is next port of call, someone has sent me software not had time to try it yet.
J - ha ha i might work up to boost 9 when my balls have grown a bit  :jumping:
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #3 on: January 09, 2011, 09:58:48 pm »
Have a look at the settings on the back of the instructions I am not sure if they are boost 9?
you have scribbled out your older settings and put your newer ones on which says 9.
looks like i will have to speak to revo direct about this and see if they will set it for me
Offline muckipup
  • -Receive: 25
« Reply #4 on: January 13, 2011, 02:57:00 pm »
I had the same problem with the previous Select Plus switch.  I downloaded the software but without luck and ended up having to use the CD that came with the switch.
I can now connect to the switch OK but have a further problem where the switch will not recognise the ECU now and my previous post here with Revo Supports solution did not work
Offline SteveS
« Reply #5 on: January 13, 2011, 07:22:14 pm »
i found it online... let me have a look
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
Offline SteveS
« Reply #6 on: January 13, 2011, 07:23:05 pm »
SOLD!! :(
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #7 on: January 14, 2011, 12:20:34 pm »
www.revotechnikftp.com/downloads/select/selectplusvag1030.zip
username:select
Password:selectplus
thanks steve, but i understand that as i have the old select switch only a dealer or revo can programme it for me as this software is designed for use with the new SPS switch only?
Offline SteveS
« Reply #8 on: January 14, 2011, 12:26:51 pm »
doh, that i don't know :-|
SOLD!! :(
