Author Topic: S3/R32 Brake Upgrade  (Read 47116 times)
Offline vRS_Pagey
  • -Receive: 59
Re: S3/R32 Brake Upgrade
« Reply #45 on: January 18, 2011, 04:34:39 pm »
Wrong! Hilda Ogden moved away from Corrie Street, she didn't die. Jean Alexander is still alive, too.  :smiley:
Coronation Street guru.................. :P
Offline simonp
  • -Receive: 38
  • No longer a Golfer
« Reply #46 on: January 18, 2011, 10:47:43 pm »
Know naff about brakes, though!
Offline SurreyED30
« Reply #47 on: November 30, 2013, 06:02:40 pm »
Hi all,
I know this thread is nearly a year old but I need to know what brake pipes I need to replace as I just read on page 2 that I need new ones,
I will be fitting my S3 set up during this week along with some Coilovers, your help here will be much appreciated.
If any one has a link too the ones I need to fit my eddy I'd be really greatful :happy2:
J
Offline Thor
  • -Receive: 25
« Reply #48 on: November 30, 2013, 06:57:21 pm »
Hi all,
J
These are the ones i used fitting my S3 front brake calipers,
http://www.brake-lines.co.uk/hel-brake-lines-for-volkswagen-golf-mk5-3.2-r32-4-motion-from-1k-4-000-001-2005-2007.html
                                     Mk6 GTI
Offline SurreyED30
« Reply #49 on: November 30, 2013, 07:05:45 pm »
Hi all,
J
Hi mate
Thanks for your post  :happy2: is this all I need now to install them hose wise?
J
Offline Thor
  • -Receive: 25
« Reply #50 on: November 30, 2013, 07:26:50 pm »
Yeah if you get the full set of hoses,  The fronts fix into the caliper and the rears into the small brake pipe on the caliper. iirc  :happy2:
                                     Mk6 GTI
Offline bigmig95
  • -Receive: 50
« Reply #51 on: November 30, 2013, 08:36:17 pm »
For the fronts some of the guys on here use these HEL lines, available from DaveB here on the forum, they have an angled banjo for better brake line entry on the caliper.
http://www.mk5golfgti.co.uk/forum/index.php/topic,66497.msg730250.html#msg730250
The OEM hose kit for the R32 front brake conversion, a straight fit on the GTI is:
FLEXI HOSE 1K0611701N qty 2
BOLT N10647602 qty 4
SCREW N90948802 qty 4
SCREW N91073301 qty 6
BRACKET 1K0611841A
BRACKET 1K0611842A
SCREW N90718601 qty 2
PIPE 1K0611763A
PIPE 1K0611764A
CLIP 191611715 qty 2
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #52 on: November 30, 2013, 08:38:47 pm »
Does anyone have the part number for the dust shields? Iv got the calipers, discs and pads.
Offline SurreyED30
« Reply #53 on: November 30, 2013, 08:42:34 pm »
Didn't think I'd need the rears so didn't order them  :confused:
BRACKET 1K0611841A
BRACKET 1K0611842A
PIPE 1K0611763A
PIPE 1K0611764A
Thannks man just ordered the same set  :happy2: but now I've read Thor's post I think I need to order the rear for the fronts to  :scared:
Offline bigmig95
  • -Receive: 50
« Reply #54 on: November 30, 2013, 08:44:00 pm »
Left Hand Shield 1K0615311C
Right Hand Shield 1K0615312C
Offline Thor
  • -Receive: 25
« Reply #55 on: November 30, 2013, 08:44:34 pm »
You can just re use your existing rear hoses, but i think it is better to replace everything.  :happy2:
                                     Mk6 GTI
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #56 on: November 30, 2013, 08:46:48 pm »
Are you meaning the rear caliper? Or the rear hoses on the front caliper?
Offline doylebros
« Reply #57 on: November 30, 2013, 08:50:34 pm »
£9.61 each full retail inc vat
Offline SurreyED30
« Reply #58 on: November 30, 2013, 08:56:56 pm »
Having thick moment, use the existing rear hose that are on the rear of the front caliper if that makes seance ? Never done brakes before man :ashamed:
Offline SurreyED30
« Reply #59 on: November 30, 2013, 08:57:27 pm »
^^^^That's what I meant  :signLOL:
