Author Topic: Tutorial - How to Update RNS-510 Firmware. ***New Links & Firmware*** 19/02/12  (Read 369675 times)
Offline toosmiles
  • -Given: 22
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92286.0.html
Load up VCDS, click on navigation, go into adaption and IIRC change channel 50 to 1.
Reboot the rns and it should work.
done m8,thanks alot
heres what came up
delivery part number 1T0035680C
HW-version H11
SW-Version 2850
SV SW-Version C_EU_9.250_t1
HW Vehicle 0xC201
SW Vehicle 0x44340001
Active map-west europe
map version HDD 7690
Golf R mk6 R-tech tuned GTX3071r
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
done m8,thanks alot
heres what came up
HW-version H11
SW-Version 2850
HW Vehicle 0xC201
Looks like you could do with a map update  :)
Offline toosmiles
  • -Given: 22
done m8,thanks alot
heres what came up
HW-version H11
SW-Version 2850
HW Vehicle 0xC201
cool,is there a link on here or do i have to buy a disc m8?
Offline toosmiles
  • -Given: 22
ive downloaded the firmware 3810a if thats right?
ive got some V12 maps now on dvd and sd card,do i need to update firmware or just stick the disc in?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Update the firmware first and then do the maps after it,
Make sure ignition is off and then insert the firmware disc in
Offline toosmiles
  • -Given: 22
cheers guys
ill give the newer firmware a go 5274 modified then stick the dvd sd card in
is it just open car and stick the firmware disc in?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
cheers guys
The V12 maps need a DVD dual layer, preferably DVD+R DL from Verbatim, burned at the slowest speed possible.
Offline toosmiles
  • -Given: 22
cheers guys
oh right ive burned them on normal dvr-r,ill do it on dual layer now
also ive downloaded the firmware you said but its in 3 parts? how do i put them together
thanks for your help anyways guys :happy2:
Offline toosmiles
  • -Given: 22
ive built the 3 files into an iso with image burn hopefully and burning now ;)
then ill burn the v12 maps again on dual layer slow or can i stick the sd card in with the maps on?
cheers
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
My posts have been erased by a Mod/Admin... :ashamed: Ok, I guess I shouldn't mention publicly the other forum due to legal issues. :laugh:
Why do you say SD card when it's supposed to be DVD+R dual layer? :confused:
Offline toosmiles
  • -Given: 22
ive read that you can install this v12 map through the sd card also on gps forum,using the rns maps tool
will the iso build through imageburn be ok?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Yes you can, but preferably you do it with a DVD+R DL. If that works well, why bother passing the maps to a SD card?
I'll send you a PM with the link with the info you requested about upgrading the maps with a SD card. :wink:
Offline NorfolkJim
Morning caps.
New on here but it seems the font of all knowledge for the RNS510!.
I've just obtained one to put in my Aug 2007 Passat Sport TDi 170 (200) to replace the old RCD300. I've recently had an MFD2 in the car which worked fine through my MFD+ on dash.
The RNS510 I obtained is an old one 1TO 035 680A HW: H04 and SW:1000 made 10:12:2007.
I installed it and to start with the screen wouldn't react for putting code in. After disconnection and retry bingo it worked and after putting code in all worked fine except it's asking for map DVD which I don't have............... anyway it doesn't seem to want to connect to the car and won't run off with ignition or link into my MFD+. To me this sounds like the drain issue people talk about as you have to actually switch radio off.
I have downloaded the  SWL fix to see if that helps things first and have also downloaded the 4020A Firmware and also the 1200GW fix for power drain (I think).
Mine has the 'i' symbol top right so how do I go about this?
I assume I switch on but must not have key in ignition and then insert the SWL fix and press Setup 'i' and ejct and wait and see. If all works do I then insert 1200GW drain fix or 4020A firmware update??
Lots of questions but what maps should I be hunting for - I know I may have to pay for them but how up to date can I get on it after doing the above??
Many thanks in anticipation - yes I know it's a Passat but there doesn't seem to be a forum like this for them?? After all I do have 200 hp in a 2.0TDi and 430Nm................  :laugh:
Offline NorfolkJim
Also where and what version maps should I be looking for???? There seem loads
Offline NorfolkJim
Well it wouldn't take the SWL fix DVD so tried putting in the 4020A DVD and it worked and showed up through the MFD+...................... system re-started and seemed ok. Switched engine on and still seemed ok but didn't switch of radio?? Left it for a while and took key out - switched radio on again and it asked for the SWL disc again and wants to re-load it again!"!!! Why is this?? It also won't accept the battery drain disc 1220GW - what have I done wrong please.....................................
