Author Topic: Tutorial - How to Update RNS-510 Firmware. ***New Links & Firmware*** 19/02/12  (Read 369714 times)
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: Tutorial - How to Update RNS-510 Firmware.
« Reply #45 on: May 28, 2011, 09:15:36 am »
I'm away at the moment so will update the thread if needs be when i get back.
397X is the latest out there but from everything i have read it is still a beta. Some people have it working with V7 maps, some have difficulty searching for the normal POI's. Some have it working with modified maps and some don't. So i will probably keep the 397X to a seperate thread so that there is no confusion over it being a beta.
Also it will only work on B & C revision units.
Offline alexperkins
  • -Receive: 99
« Reply #46 on: May 28, 2011, 09:24:59 am »
397x is a very stable firmware for a beta release, but for POIs to work, you need to use an unmodified 7388 disc and import the Speed Cameras etc via Personal POIs on your SD Card.
Offline nc35
  • -Given: 40
« Reply #47 on: May 31, 2011, 05:24:23 pm »
Just a quick query...
Any benefits of 2760 over 2720???
Nobody on Google seems to have any comments
No Golf anymore.
Enjoyed the last five years of ownership of Mk5 & 6 GTIs.
Plus an excellent forum for knowledge and new ways to deplete the bank account.
Thank You Everyone.
Offline Leonard
« Reply #48 on: June 23, 2011, 10:38:02 pm »
How severe is the battery drain?
Just fitted a version C to my March 2007 and not noticed anything so far.....
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #49 on: June 23, 2011, 10:43:49 pm »
It will appear after about 2-3 days of the car being static. Then after that it will happen quite often.
However i had a Mar 2007 car previously and i never suffered battery drain. It depends on when your car was built and if it is a MY2007 car or a MY2006 that was just registered in Mar 2007. Hopefully you will be lucky and it will be fine  :happy2:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #50 on: June 23, 2011, 10:47:33 pm »
My March 07 built Jetta (K gateway) has been fine too.
One thing I did find that while the modified firmware didn't cause battery drain on my Mk5 (with ver E gateway) it won't work with the Rear Camera so updated it to a AD and all it good  :happy2:
Offline Leonard
« Reply #51 on: June 23, 2011, 11:09:35 pm »
Well fingers crossed! It shows as a 2007 car on the VIN no..
Thanks Carl and Steve
Offline chris s
« Reply #52 on: June 24, 2011, 09:51:27 am »
I meant to add my update to this post... The local VW dealer (Benfiled Newcastle) did me proud in the end... on the last day of warranty they gave me a new Sat Nav unit, replaced a couple of faulty units with the Immobiliser and a few other minor points...
Regarding the Sat Nav... they told me the HDD was corrupt hence why it appeared to have 0 memory and why the only means of using the Nav was to have the NAv disc permenantly in the player... anyway all is good now... I appear to have a working unit... my only small gripe is that I can only still use memory cards with a maximum of 2GB... I've decided that I will not mess with the firmware anymore and just get on with driving the car...
Lesson Learnt  :happy2:
Candy White Edition 30 DSG
Revo Stage 2+
ITG, BCS TBE, Autotech HPFP
WALK
R32 Brake upgrade
S3 IC upgrade
odyseus
« Reply #53 on: July 04, 2011, 07:18:02 pm »
Hi all,
My first post :-)
I've got a Sept 2007 GT Sport Tdi 170 that was fitted with a rnc310.
I've since fitted a rns510B firmware 1120, v7 maps. No battery issue.
I really want 6 digit postcode search and so I have upgraded sw to josi 2270 battery drain fix.
My first question is, how can I tell if I will suffer from the battery drainproblem or not?
Second question is, would I be better off installing sw 1300 instead and are there any issues downgrading firmware?
All the best
John
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #54 on: July 04, 2011, 07:50:06 pm »
On a Sept 07 car you shouldn't have any issues  :happy2:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #55 on: July 04, 2011, 10:20:49 pm »
As Steve says a Sept 07 Car will be fine as it will have at least an L revision gateway if not higher.
1300 firmware is higher/newer than 2720. It is the same as 2800 except for no voice control. But unless you have Bluetooth and have wired up the mic accordingly you wont have that so won't need it so fill your boots and install away :happy2:
odyseus
« Reply #56 on: July 06, 2011, 09:41:27 pm »
Thanks for your replies chaps!
In the end I installed the Josi 2270 firmware (just to be safe) and Western Europe Maps V 7333 - I assume this is the latest, but the maps are still quite out of date, as it doesn't show an extension to our housing estate that is over two years old at least?
The only thing I need to do (possibly) is get the local dealer to activate the stereo steering wheel access via the VAG-comm, so I can access volume from the steering wheel stick?
I don't need voice, bluetooth etc- too expensive a luxury to be hands free :(
John
Offline GazB
« Reply #57 on: July 11, 2011, 09:38:48 pm »
All worked for me on a version C - Cheers chaps ;)
zaid
« Reply #58 on: August 25, 2011, 01:28:03 am »
Just finished updating my RNS 510 according to the procedure specified, really thanx man its great  :happy2: :congrats:
zaid
« Reply #59 on: August 25, 2011, 01:30:05 am »
Looking forward if some one can tell from where i can buy a rear view camera, genuine, i have PASSAT R36 2010 model
Thanx
