Author Topic: RNS510 Firmware update - Now sorted thanks VRS Carl & Darren  (Read 25520 times)
Offline Kiwi
« on: January 13, 2011, 12:59:11 pm »
Trying to load firmware, and got this when I put disc in?
What does it mean? What is a clamp state?
« Last Edit: January 13, 2011, 07:27:07 pm by Kiwi »
Offline Norbreck21a
Re: Ok What does this mean in Laymans terms? RNS510 Firmware update
« Reply #1 on: January 13, 2011, 01:03:03 pm »
See this thread for VrsCarl :
http://www.mk5golfgti.co.uk/forum/index.php/topic,23779.0.html
Look torwards the bottom of the first first post (a few lines below the photos) where he tells you what to do if you get precisely this error  :happy2:
Andrew
Offline Richn83
  • -Given: 49
  • -Receive: 86
« Reply #2 on: January 13, 2011, 01:07:43 pm »
As Andrew has just pointed out clock is the wrong format.
see below from my-gti website.
Note: If you receive a clamp state error ‘a swl disk is detected but it is unvalid because of clamp state. please switch clamp state to hour mode and re insert disk’ this means you need to change the time format of the clock in the RNS 510 from 12 hour to 24 hour clock.
only took a quick search and 3 words in google  :happy2:
Offline Kiwi
« Reply #3 on: January 13, 2011, 01:22:36 pm »
ok but now I have this.......
What now, oohh and I have googled this one, nothing much coming up
Offline Richn83
  • -Given: 49
  • -Receive: 86
Re: Ok What does this mean ERROR 010306? RNS510 Firmware update
« Reply #4 on: January 13, 2011, 02:34:11 pm »
which firmware are you trying to load and what unit, as could be a number of reasons.
Offline mortygttdi
  • -Receive: 146
« Reply #5 on: January 13, 2011, 03:57:16 pm »
I believe Colin has 2680 and I have sent him firmware 2720 which I used on my RNS510???
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #6 on: January 13, 2011, 04:02:33 pm »
The only time i have seen that happen is when someone has tried to put the wrong firmware on a unit. (Trying to load 1100 on a A revision unit)
Has the 2720 been modified in any way?
The quick solution would be to download the 276X firmware i have linked in the tutorial thread. :happy2:
Offline Kiwi
« Reply #7 on: January 13, 2011, 04:06:27 pm »
RNS510 Version C
VW2720 Firmware
Offline 182_blue
  • -Receive: 54
« Reply #8 on: January 13, 2011, 04:16:55 pm »
RNS510 Version C
VW2720 Firmware
Where did you buy it ?
Offline Kiwi
« Reply #9 on: January 13, 2011, 04:26:51 pm »
RNS510 Version C
VW2720 Firmware
Bought the unit from a bloke off Ebay Naviplanet is his tag name.
http://shop.ebay.co.uk/naviplanet2010/m.html?_nkw=&_armrs=1&_from=&_ipg=&_trksid=p3686
Came with VW code card, GPS unit, and the Sat Nav
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #10 on: January 13, 2011, 04:29:38 pm »
As i said earlier try using 276X firmware.
Offline Kiwi
« Reply #11 on: January 13, 2011, 04:51:38 pm »
Downlaoding it as we speak, just need a DVD to burn it too now.............. :fighting:
Offline mortygttdi
  • -Receive: 146
« Reply #12 on: January 13, 2011, 04:53:09 pm »
Just use the one I sent you Colin
Darren :happy2:
Offline Kiwi
« Reply #13 on: January 13, 2011, 04:59:33 pm »
Darren :happy2:
Great Idea  :notworthy:
I'm erasing all of the disc as we speak, ready for when the downloads finished so I can upload on to the disc.
Now in the tutorial it talks about burning the disc slowly, I only have windows XP and will be using that to burn the software on to the disc, Im not sure with XP I can control the burn speed ??
Will it really make that big a difference ????
Offline vRS Carl
  • -Given: 282
  • -Receive: 241
« Reply #14 on: January 13, 2011, 05:11:27 pm »
Yes it can do.
If your using re-writable discs that can cause problems too. Only saying that as you said your erasing the disc.
I'm not sure you can create a disc from an image just using XP's in built software so you may need to download nero lite (which is free) :happy2:
