Author Topic: Yet another...Can anyone help with the revo select settings please?  (Read 9531 times)
Offline heavyd
  • -Receive: 29
Re: Yet another...Can anyone help with the revo select settings please?
« Reply #30 on: January 18, 2011, 04:55:59 pm »
Well after £108 on a new MAF sensor,
      Lambda (Idle)   Lambda (Partial)
   TIME   Self-Adaptation   Self-Adaptation
Marker   STAMP    %    %
   0.04   0   0
   0.18   0   0
   0.3   0   0
   174.52   -2.7   -0.4
   174.63   -2.7   -0.4
Hope fully fingers crossed the fault doesnt return :jumpmove: At least the values are better than before
I lost the bolt for the maf that goes into the twintake though :sad1:
Think I might sell the car on at this rate!!!!!!!
Thanks for the help folk :happy2:
How much will it be for a twincooler then Dave?
« Last Edit: January 20, 2011, 04:36:14 pm by heavyd »
Offline heavyd
  • -Receive: 29
« Reply #31 on: January 19, 2011, 05:28:13 pm »
Oh well, the joy was short lived........
Has anyone any other idea what it could be?
Does anyone know if theres any reason why it would be running so rich on idle, yet ok readings whilst driving about? If it was the lambda sensor, would the readings whilst at revs also be higher, and if it was a vacuum leak, these readings would also change, but the continue to remain constant whilst at high rpms?
A bit daunting considering MOT due very soon, bet it fails on emissions :sad1:
Is anyone after a maf :signLOL:
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #32 on: January 19, 2011, 05:39:50 pm »
You know that there's 2 lambda sensors right? try and swap the old with the new and put the new instead of the second one?? just a thought  :smiley:
Over the top mod list ;o)
Offline heavyd
  • -Receive: 29
« Reply #33 on: January 19, 2011, 10:11:12 pm »
I wasnt sure if they were the same part number. By the looks of it I might need to up the fuel ratio, as it looks like the timing is too rich when the timing is pulling.
'd just stayed stage 2 b;uefin :surprised:wish I'
Offline PDT
  • -Receive: 142
« Reply #34 on: January 19, 2011, 10:35:14 pm »
Why did you change the lambda sensor?
Offline heavyd
  • -Receive: 29
« Reply #35 on: January 20, 2011, 05:56:40 am »
I didnt. I was trying to rule things out that could be causing the fault. Only fuel pump, lambda sensor and maybe the pcv left from what I can gather that can be at fault?
