Author Topic: Advice Required: Rear Door Not Opening  (Read 6479 times)
Offline xxx_mojo_xxx
  • MUBster DUBster
« on: January 16, 2011, 10:00:23 am »
My rear door is refusing to opening.  I can hear the door lock clicking (twice) but I can't open it from the inside or outside.
Any ideas what it may be and how I can get the door to open please?
Re: Advice Required: Rear Door Not Opening
« Reply #1 on: January 16, 2011, 02:31:45 pm »
This happened recently to a friend of mine who drives an Octavia taxi - Door wouldn't open. His dealer replaced the whole door lock mechanism but it still didn't solve it. Following my advice he went online and found out that a plug connection had come loose. IIRC the connector is in the rubber flexi thing at the hinge end of the front door on the same side of the car as the problem door.
HTH for now but I don't know any more. I could ask him for more detail when I next see him but that might be a few days.
  • MUBster DUBster
« Reply #2 on: January 16, 2011, 04:52:25 pm »
Thanks Robin I will have a look.  Presumably the plug connection cannot be accessed unless you can open the door?  BTW, I can hear the lock mechanism clicking as if it is trying to open?
« Reply #3 on: January 16, 2011, 05:24:01 pm »
Apparently the plug part is in that concertina rubber on the front door.
Offline Snoopy
  • -Given: 31
« Reply #4 on: January 17, 2011, 08:09:43 pm »
I read this on here the other day. Don't know if its any use to you.
If you have vagcom/VCDS go into central locking and perform an output crash test this will pop the doors regardless of a fault.
« Reply #5 on: January 17, 2011, 09:08:10 pm »
....A crash test, did you say? You might pop more than just the doors  :laugh:
  • MUBster DUBster
« Reply #6 on: January 17, 2011, 09:28:09 pm »
Is this for real?  I don't want to set off the airbags!!!
Offline Snoopy
  • -Given: 31
« Reply #7 on: January 18, 2011, 07:00:14 pm »
I read it on here in the general section last week in responce to a door been stuck
Try a search any you should be able to find the original poster.
  • MUBster DUBster
« Reply #8 on: January 21, 2011, 01:04:38 pm »
Does any one have a screenshot of where in VCDS I can pop open the doors please?
Thanks in advance.
  • MUBster DUBster
« Reply #9 on: January 21, 2011, 10:47:25 pm »
I went into Module '72-Door, Rear Right' and did a 'Output Test-03'.  Door still didn't open.
I did notice a message saying that the door lock unit was in 'safe mode' when I go into 'Measuring Blocks' 'Group 05'
Any ideas?
« Reply #10 on: January 21, 2011, 10:54:49 pm »
Mo, have you not checked out what I suggested (the physical connections)? - It worked for my friend with exactly the same problem. Water and moisture can get in there over a long time.
  • MUBster DUBster
« Reply #11 on: January 22, 2011, 12:11:59 am »
I tried...but it was too dark to work out how to take the rubber bits off.  I will have another look in the morning.
P.S.  I got the door open by constantly unlocking and locking the door and pulling the outside handle.  I suspect the problem is still there though and may happen any time.
  • MUBster DUBster
« Reply #12 on: January 27, 2011, 06:41:10 am »
Car booked in at dealership for this Friday...let's see what they come up with.
Offline Aaron_RJ
« Reply #13 on: January 30, 2011, 01:06:13 pm »
twas me who posted about a crash test it wont set off airbags as you are only in door electronics
2007 GTI | 18'' Monzas |Xenons|Highline|MFSW|Lux pack| Factory Tints |Cruise control
Mods: VWR Quickshift |Forge DV |Autotech HPFP| Sportlines | |Goodrich hoses |Milltek non res TBE | Stage 2 map | Custom CAI
  • MUBster DUBster
« Reply #14 on: February 01, 2011, 09:49:39 pm »
Cheers, car going back in on Thursday.  Replacement door lock mechanism on order.
