Author Topic: DSG hesitating on downshift  (Read 10963 times)
Re: DSG hesitating on downshift
« Reply #15 on: January 17, 2011, 04:44:35 pm »
....That's what I was alluding to. Same difference - Lou is 'forcing' the shift. I still say it's not a great way to drive IMO whether DSG or manual or on any vehicle.
Why is that a bad way to drive a Manual?
In a manual you stick the clutch in, and select 2nd from 4th, and ready for a junction, bend or get instant acceleration capability for an overtake manouver, as long as you don't over-rev the engine what is the problem in a manual?
 :popcornsoda:
....Sure, you can do it but IMO it omits using the engine braking. As you rightly point out, it's important not to over-rev the engine and that's easier to do if you're in the habit of double-clicking. I think it's a lazy way to drive too. Just the way I've been taught.
« Reply #16 on: January 17, 2011, 04:52:18 pm »
If I was being lazy I would just let the box downshift itself.
By double clicking and dropping 2 gears I have used more engine braking.  :confused:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #17 on: January 17, 2011, 05:03:00 pm »
I certainly don't see a problem with dropping more than one gear. As long as you get the revs to match for a smooth change then it's fine.
I think the problem would be if you just went from 4th to 2nd and sidestepped the clutch.  :laugh:
« Reply #18 on: January 17, 2011, 05:05:49 pm »
Robin, as you have such fast road/track experience, have you noticed anything similar if you, for example, had to hurry a shift into a bend?
I wonder if it's worth polling the DSGers amongst us regards hesitation (in auto mode) as I described.
....I don't have a lot of track experience - Some, but not as much as many here. But I do have 90k miles of DSG experience in my GTI.
When I first had my DSG way back in 2005, I didn't feel comfortable with the small plastic oem paddleshifters and drove for several thousand miles in D but always used S for overtakes and a series of spirited bends. I've never liked the feel of nudging the floor stick and have only used that method less times than I can count on one hand. In reaching for the floor stick I find it natural to expect a gate.
So, at around 6k miles my Mechatronics module hiccup'd and VW replaced it under warranty although there was only one incidence and the car drove normally straight afterwards. I have experienced, like many others here, clunky shifts but they have invariably been down to cold temperature. I now always let my engine warm up so that the revs drop before I engage any gear.
From time to time I have experienced hesitancy but only in D or S and it has always seemed to be just a delay on gear selection probably down to the DSG brain momentarily being unsure about what my right foot was asking for. It has always cleared up after a few miles of 'retraining' - The DSG 'learns' your driving style.
Since Revo remapped my DSG box, none of these problems have occurred except for the cold temperature IF I don't settle the engine first.
I hope this helps in some way  :happy2:
« Last Edit: January 17, 2011, 05:07:30 pm by RedRobin »
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #19 on: January 17, 2011, 05:08:57 pm »
That's odd :confused:
Mine hesitates in P & N as well :evilgrin:
« Reply #20 on: January 17, 2011, 05:12:21 pm »
....Meaning that I have experienced no hesitancy while using M  :P
Offline QD MBE
  • -Receive: 102
« Reply #21 on: January 17, 2011, 06:51:40 pm »
x2.  Experience more engine braking by dropping 2 gears.  Perhaps that is just me and you Ian. Guess I am lazy!  But at least I use my left leg!
Right gear right time, I don't want to spend 100 yards changing 2 gears in my manual box, where I can slap it down 2 and use the engine braking available in one constant flow, and thereby not unsettling the car.
Just the way i was taught to drive, on several courses I have been on.  ETTO.
« Last Edit: January 17, 2011, 07:30:07 pm by stokeballoon »
Offline LouCyffer
  • -Given: 36
  • -Receive: 63
« Reply #22 on: January 17, 2011, 07:35:21 pm »
Great info, thanks Robin
« Reply #23 on: January 17, 2011, 07:44:52 pm »
....You're very welcome  :drinking:. We all try to help each other.
Offline chungster
« Reply #24 on: January 17, 2011, 07:48:53 pm »
Yup no probs with box shifting in a manual imo...if it gets u into the right gear for the bit of road ahead. i do it now and again.
no delay whatsoever either  :wink:
« Reply #25 on: January 17, 2011, 07:53:36 pm »
....That's right - ETTO and it's the way I've been taught (rightly or wrongly) and it's the way I'm most comfortable with.  :smiley:
Just make sure you don't go straight from 3rd to 1st when DSG  :grin:. 1st is a very short gear on the Mk5 GTI.
I think that there's more liklihood of getting it wrong on DSG than manual. Yes, the DSG will do it and I hear what some of you guys are saying but I think that DSG is happier going through the gears rather than 'boxing'.
« Last Edit: January 17, 2011, 07:55:54 pm by RedRobin »
« Reply #26 on: January 17, 2011, 08:00:11 pm »
Actually thinking about it further: I don't agree with whoever said that the car is more stable when boxing - It'll depend very much on how you want to use the throttle at the time, by putting lots of power suddenly into a much lower gear you may risk unsettling the car. Anyway, we [for Carl's benefit] can talk about this all night and achieve nothing.
« Last Edit: January 17, 2011, 09:00:33 pm by RedRobin »
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #27 on: January 17, 2011, 08:28:50 pm »
Anyway, I can talk all night and achieve nothing.
That's the most truthful thing i've heard you say Robin  :booty: :evilgrin:
« Reply #28 on: January 17, 2011, 09:01:40 pm »
:laugh: - I see what you did there, Carl.  :P  :grin:
« Reply #29 on: January 17, 2011, 09:42:08 pm »
It will only go into 1st if you are going slow enough, well at least with OEM software that is.  :smiley:
Also you can't 'box' per se with a DSG box as you can't miss gears, you can only simulate it.  :wink:
