Author Topic: S3 Jacking pads to a MK5 Golf - Can it be done?  (Read 13841 times)
Offline Nodz
  • -Given: 73
  • -Receive: 103
Re: S3 Jacking pads to a MK5 Golf - Can it be done?
« Reply #15 on: August 05, 2011, 06:28:20 pm »
does anyone have the part number for these ?
here you go
Offline gillm
« Reply #16 on: August 05, 2011, 06:43:17 pm »
ta
west tuned gt28 @ 340hp
Offline gobbleplease
  • -Given: 64
  • -Receive: 48
« Reply #17 on: August 05, 2011, 08:46:32 pm »
They cost £45 for the full kit at the dealers just now including vat and the covers, i ordered mine a couple of days ago ! Bargain !
MK7 GTI - ARRIVING DECEMBER
Offline liveround
« Reply #18 on: August 05, 2011, 09:32:17 pm »
I need to remove all 4 wheels for a week to get them refurbed. Where do I support the car?
lr
Offline bodger00
  • -Receive: 20
  • A wish called Zonda
« Reply #19 on: August 05, 2011, 09:34:33 pm »
Axle stands under the sills mate :happy2: Use 4 and make sure you raise the car onto them carefully :grin:
Offline Snoopy
  • -Given: 31
« Reply #20 on: August 05, 2011, 09:47:06 pm »
.There are 2 holes on the fronts and it can easily be put in the wrong one ( ask JPC )  :laugh: The design is such that once they are locked in with the weight of the car, they are not coming out without a serious fight.  :rolleye:
Two holes on the front? Do you meen the two holes at the rear and use the front one? Im confused.
Heres what i bought last week with prices for anyone interested
Ramp Lifting pads from Audi S3 RRP exc VAT
(x1) 8P0 802 845 Front Left Jack Pad £8.03
(x1) 8P0 802 846 Front Right Jack Pad £8.03
(x4) 8N0 804 583 Rubber Buffers £1.53 each
(x2) 8P0 802 847 Plastic Jack Pad Plugs £8.03 each
Sadly i did not get them fitted intime for my car to go into the dealers and i now have large bits of sealer scrapped off and hanging down from the inside of the jacking points on the front of the sills.  :sad:
So are the back ones fitted on the holes nearest the front, Or the holes nearest the rear. As Teutonic_Tamer thread also shows the rear ones used.  :confused: TTs thread on his fitted to his mk5
« Last Edit: August 05, 2011, 10:01:23 pm by Snoopy »
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #21 on: August 05, 2011, 09:51:42 pm »
These fit on any MK5 Platform car so Audi A3/S3 8P, Skoda Octavia Mk2 (incl FL as i have them on mine), Seat Leon, Scirocco and of course Golf GTi
Offline DaveyCupra
« Reply #22 on: August 06, 2011, 02:37:01 am »
CupraR,
I have these fitted to my mk2 leon cupra mate, fitted exactly same as golf and easy to do.
« Reply #23 on: August 06, 2011, 08:38:48 am »
Copycat.  :P
Offline Cupra R
  • -Given: 18
« Reply #24 on: August 06, 2011, 08:45:29 am »
CupraR,
Cheers Davey.
Maybe I should of said, I'd bought and fitted a set ages ago.
I now find though that some garages can't get onto them and I can't get to them even with a low slung trolley jack.  Car is on a set of Eibach Sportline springs, so must of lowered it too much for these to be of use for me really.
Offline Snoopy
  • -Given: 31
« Reply #25 on: August 06, 2011, 09:05:10 pm »
I just pulled the blanks out to fit the front ones and water came out the drivers side front one :surprised: anyone know if theres a drain for that box section somewere as thats not a good sign.  :scared:
Offline GLIDN
« Reply #26 on: August 07, 2011, 02:02:54 am »
Thanks to this link i have ordered mine.
But not as lucky as you lot. I have to pay $150NZ with 20% discount.
None the less only arrive the end of the month. Will fitthem once I receive them.
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #27 on: February 25, 2012, 07:33:11 pm »
OEM Audi S3 jack pads fit nice !!  :thumbsup:
A posting I did on another forum:
front:
rear:
Fitting instruction is German, but the picturs tell the complete story:
http://www.a3quattro-forum.de/pdf/Wagenheberaufnahme.pdf
parts numbers:
8N0 804 583 rubber (4 x)
8P0 802 845 cover left front (1 x)
8P0 802 846 cover right front (1 x)
8P0 802 847 cover left + right rear (2 x)
Use some wax spray to conserve the body and silicon to help slip in.
Not the same:
http://www.ecstuning.com/ES251835/
http://forums.vwvortex.com/showthread.php?5110208-Do-These-Jack-Pad-Adapters-From-ECS-Really-Work
As you can see I prefer the S3 8P / TT 8J parts. Only these close the plastic trim!
"You get what you pay for."
