Author Topic: Does anyone have an oil filter drain tool (T40057) I can borrow?  (Read 5244 times)
Offline alexperkins
  • -Receive: 99
Hi Guys
Recently got my ED30 and want to do an oil change at the weekend on it.
I like to do things properly, therefore would prefer to use the proper tool (T40057) to drain the oil filter housing prior to removing the filter (as per the official service guide)
One of these:
Does anyone have one that I could possibly borrow for a day?
Im located in Poole, down in Dorset
Offline PDT
  • -Receive: 142
Re: Does anyone have an oil filter drain tool (T40057) I can borrow?
« Reply #1 on: January 19, 2011, 10:39:37 pm »
In all honesty you wont need it. I have one in my toolbox, used it once and realised it was pointless and has no benefit whatsoever.
Offline alexperkins
  • -Receive: 99
« Reply #2 on: January 19, 2011, 10:42:45 pm »
Fancy selling it?
I'm not up for breaking the valve as I've read it's easily damaged :(
Offline PDT
  • -Receive: 142
« Reply #3 on: January 19, 2011, 10:52:15 pm »
No need to touch the valve, just remove the cap and use the right size filter housing socket (36mm i think) to take the housing off.
Offline alexperkins
  • -Receive: 99
« Reply #4 on: January 19, 2011, 10:53:42 pm »
So don't bother draining the housing prior to removal? This is the first car I've worked on with cartridge filters!
Offline PDT
  • -Receive: 142
« Reply #5 on: January 20, 2011, 12:47:06 am »
No need to, once you remove the housing you can just tip any oil thats inside it out into your oil bucket
Offline alexperkins
  • -Receive: 99
« Reply #6 on: January 20, 2011, 08:53:06 am »
Many thanks PDT
« Reply #7 on: September 18, 2011, 11:38:22 am »
Im about to order one but am wondering why, as Dave suggested you cant drain from the sump plug 1st and then tip out any left in filter housing when you remove it?
Cleaner method as no / less risk of making mess, is that it?
« Reply #8 on: September 18, 2011, 11:40:34 am »
I do the same as Dave when i have done them at work :happy2:
« Reply #9 on: September 18, 2011, 11:44:18 am »
Drain from sump plug 1st & carefully remove filter housing?  :happy2:
« Reply #10 on: September 18, 2011, 11:51:19 am »
This could be helpful when changing your oil.
http://www.awesome-gti.co.uk/product.php?xProd=27521&xSec=159
« Reply #11 on: September 18, 2011, 11:59:12 am »
Good find that, think what I need is a pig that can be plugged so I can transport it to work to dispose of the oil
Offline baldwined30
« Reply #12 on: September 18, 2011, 10:21:25 pm »
I've gotta change my filter and housing next weekend! Are we saying that there is a separate plug for draining the oil prior to removal of the filter housing and filter?
Ed30
« Reply #13 on: September 18, 2011, 10:24:40 pm »
The plastic filter housing has a drain valve, then there is the drain plug in the sump  :happy2:
Offline baldwined30
« Reply #14 on: September 19, 2011, 09:24:38 am »
Cheers mike! As always!! got a cracked filter housing too, like you said before, perfect time to change the oil, whats best? whitout searching the forum!
Ed30
