Author Topic: Valeo LED Mk5 Tail Lights Modification....  (Read 137202 times)
Offline Weston
Re: Valeo LED Mk5 Tail Lights Modification....
« Reply #30 on: January 24, 2011, 06:55:11 pm »
1 - RedRobin
2 - cmdrfire
3 - Weston
4 -
GTI going...
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #31 on: January 24, 2011, 06:56:56 pm »
1 - RedRobin
2 - cmdrfire
3 - Weston
4 - DanishmkVgti
5 -
Over the top mod list ;o)
« Reply #32 on: January 24, 2011, 11:28:13 pm »
For anyone who wants to buy some Valeo LED tails, I understand this is a current reasonable source cheaper than from VW dealers:
http://www.kunzmann.de/shop/en/tuning-styling-vw-golf-5-v-led-rear-lights-set-candy-red-for-vw-golf-5-v.htm
^ "kunzmann"!? < I don't think I want to translate that!
« Reply #33 on: January 24, 2011, 11:32:46 pm »
I know the controller does not require VCDS itself, but it may be necessary to set it so that both reverse lights work. Not sure, I'll wait 'til I've seen the datasheet and had a good look-over and seen the functionality.
Please bear in mind that it may be a little while before we get these - We've got to look at what sort of data we have to work with, I've got to design and lay out the PCBs, then we will get some one- or two-off prototypes made and assembled (which will probably be fairly expensive, maybe £50/side as a rough guess as there'll be machining work to be done etc). After that they need to be tested off the car, then on the car, and make sure all the functionality works as intended. After that we can got to a batch PCB house in China and get a whole bunch made for everyone, that will be a much more reasonable cost but the downside is that the batch processing will take some time (IIRC used to be 14-30 days, but may be less now).
After they come back, they'll have to be assembled, and tested, and then (being an auto engineer) I think I'd insist on a conformal coat to protect them, btu that shouldn't take too long.
The end goal will be for some inner tail LEDs that will be reasonably priced, built to near-automotive standard, and capable of a variety of functionality - "normal" operation (on with sidelights/dipped lights), brake functionality (if desired), and fog-lamp functionality (if desired) with the two inner filament lamps being used for reversing lights. No point messing about with half-assed fixes and electronics that will break over time.
....I'm impressed! I see you're pissing excellence again. I agree that this is the standard best to achieve.  :happy2:
For those of us wanting twin reverse lights, we'll have to source a white inner lens to replace the red one. I'll check, but I think Chris has direct contact with Valeo so may be able to help.
Offline Weston
« Reply #34 on: January 25, 2011, 09:39:59 am »
Twin HID reverse lights might help see what's behind  :evilgrin: The standard 1 candle power lamp is pretty useless. It'll look good being symmetrical  :party:
GTI going...
  • -Given: 243
  • -Receive: 154
« Reply #35 on: January 25, 2011, 09:53:52 am »
I'll have to disagree, with the Mk 6 RVC fitted even the darkest of nights the std. reverse light is more than enough   :evilgrin:
« Reply #36 on: January 25, 2011, 11:42:25 am »
....I don't find seeing behind at night a particular problem except that the extra reversing light would further help check out the other side. I much prefer a symmetrical look too.
Offline GTsport
« Reply #37 on: January 25, 2011, 11:49:32 am »
I'd defo be interest in this.
Ive been looking to source lights so i'd need to do that first!  But once i have  :happy2:
« Reply #38 on: January 25, 2011, 11:55:57 am »
....The list is only provisional - We are fairly confident now it can all be done but don't know costs yet, so being on the list isn't a commitment but is just a genuine serious interest in going ahead so we can buy enough purpose-made PCBs.
I think I'll add this list and Valeo source to my first post in this thread and keep it updated.
1 - RedRobin
2 - cmdrfire
3 - Weston
4 - DanishmkVgti
5 - GTsport
6 -
Offline Weston
« Reply #39 on: January 25, 2011, 01:54:33 pm »
That's cheating  :laugh:
GTI going...
  • -Given: 243
  • -Receive: 154
« Reply #40 on: January 25, 2011, 04:00:57 pm »
It's soooo cool, the camera must be very light sensitive. Really shows all there is behind the car  :P
« Reply #41 on: January 25, 2011, 04:47:15 pm »
1 - RedRobin
2 - cmdrfire
3 - Weston
4 - DanishmkVgti
5 - GTsport
6 - richardgti
7 -
Offline bodger00
  • -Receive: 20
  • A wish called Zonda
« Reply #42 on: January 25, 2011, 10:24:23 pm »
1 - RedRobin
2 - cmdrfire
3 - Weston
4 - DanishmkVgti
5 - GTsport
6 - richardgti
7 - Bodger
8 -
Offline PND
  • -Receive: 62
« Reply #43 on: January 25, 2011, 10:36:44 pm »
1 - RedRobin
2 - cmdrfire
3 - Weston
4 - DanishmkVgti
5 - GTsport
6 - richardgti
7 - Bodger
8 - PND
9 -
Offline markymark
« Reply #44 on: January 26, 2011, 09:12:25 am »
1 - RedRobin
2 - cmdrfire
3 - Weston
4 - DanishmkVgti
5 - GTsport
6 - richardgti
7 - Bodger
8 - PND
9 - markymark
10 -
