Author Topic: Check engine light disabled.. Illegal tampering?? UPDATE IT WAS TAMPERED PAGE 2  (Read 14933 times)
Offline ruffrydaz
Sorry this isn't a gti but my gt tdi 2.0..
The emissions workshop message has appeared on the mfd but the engine light should also be on.
I scanned it and this was the intake flap seizing.
I thought mine was just different but when I turn the key in the ignition sequence most lights come on but the engine light doesn't come on at all.
I think either
A) it has Been driving with the light on for ages till it burnt out.
B) bought it from a dodgy dealer?
Any ideas please
« Last Edit: March 16, 2011, 01:30:01 pm by ruffrydaz »
Offline cmdrfire
    • Commander Fire - my blog
Re: Check engine light disabled.. Illegal tampering??
« Reply #1 on: January 24, 2011, 12:32:09 pm »
The indicator lamps on the Mk5 are all LED. They have lifespans in the region of 10,000+ hours. Pretty much no possibility for it to be "burnt out" (that's not how LEDs work) but it's possible it never worked in the first place (but then again, I imagine factory quality control would have picked up a thing like that).
Offline ruffrydaz
« Reply #2 on: January 24, 2011, 12:34:42 pm »
Thanks for the reply
What's the best way to go from here.
I will post a pic soon of my startup sequence to make sure there are no other lights disabled
Offline TrickGTI
« Reply #3 on: January 24, 2011, 12:47:18 pm »
Someone needs to plug vagcom in to check if the led works you can activate it to see if the led works. But from then I'm not sure it does need to work though by law your right there. There could be a problem with te circuit board in the cluster. There are a few boffins on here who will sort you out on this...
2006 Tornado red GTI
Offline ruffrydaz
« Reply #4 on: January 24, 2011, 12:50:15 pm »
Well I bought it with emissions workshop message so I'm pretty sure someone Took the bulb out so only the message comes on and not the light.
I have vagcom btw, any idea how to check the LEDs via vagcom?
Offline cmdrfire
« Reply #5 on: January 24, 2011, 12:55:53 pm »
Again, can't take the "bulb" out - the LED will be soldered to the circuit board.
x2 on the VCDS but best wait for a vagcom experte to show up here and tell you what to do...
Offline Poppa Dom
« Reply #6 on: January 24, 2011, 01:00:50 pm »
IIRC select the instrument cluster in VCDS - you will then be able to run the self test, this checked all LED's and does a sweep test of the dials.
Offline ruffrydaz
« Reply #7 on: January 24, 2011, 01:02:03 pm »
Thanks I'll try it later
Offline ruffrydaz
« Reply #8 on: January 24, 2011, 02:05:40 pm »
Any ideas how to do this. Cant seem to find it in vcds
Offline ruffrydaz
Re: Check engine light disabled.. Illegal tampering?? * PICS ADDED
« Reply #9 on: January 24, 2011, 06:14:57 pm »
Ok im really annoyed now i think it has been tampered with..
Here is a pic all the lights come on and go off as expected except the CEL light.
Im sure this has been tampered with or a big big co incidence
Can i check the LED on vagcom or do i have to remove the cluster to check
Im sure the led or wiring has been fiddled with
Thanks guys
PIC:
Offline TrickGTI
« Reply #10 on: January 24, 2011, 06:22:52 pm »
Im not sure you could really and i think it would be a lot of effort to have it tampered with to stop the light coming on... and unless there is a hugely expensive item gone wrong one the car for the light to be on then it wouldn't be worth having it tampered with.... so you need someone on here who knows if the led for it can be turned off but i can't see that. i think its more likely that its just a huge coincidence but there is a problem with the cluster it can happen...
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #11 on: January 24, 2011, 07:48:44 pm »
When you say you had a fault code did it say MIL ON??  Not all fault codes will illuminate the CEL.
Quote
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded - MIL ON
16687 - Cylinder 3: Misfire Detected
P0303 - 001 - Upper Limit Exceeded - MIL ON
16685 - Cylinder 1: Misfire Detected
P0301 - 001 - Upper Limit Exceeded - MIL ON
Stu...
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #12 on: January 24, 2011, 08:02:29 pm »
I thought the glow plug light on a diesel was the 'check engine' light of a petrol?
Sepang Blue S4 BE Avant
Offline ruffrydaz
« Reply #13 on: January 24, 2011, 09:04:34 pm »
ub7rm:
no there is check engine for diesel and EPC for petrol
The engine light should be under the glow plug light and above the red steering mechanism
vRStu: I know but the engine light doesnt even come on at startup
« Last Edit: January 24, 2011, 09:11:06 pm by ruffrydaz »
Offline ruffrydaz
« Reply #14 on: March 16, 2011, 01:00:59 am »
Ok. When i bought the car the exhaust emission light was on in VAGCOM ONLY because of the egr and imf flap.
But the light doesnt work in reality.
Im gonna check it once and for all tomorrow. im sure it had some  black tape over it or something
When i remove the cluster cover can i just lift the dials off the board to reveal the leds without removing the needles?
thanks
