Author Topic: Does the stereo need coding for an amp/sub (soundpack?)  (Read 2221 times)
Offline SeanyK
  • -Given: 35
« on: January 24, 2011, 09:33:54 pm »
Hey folks,
I fitted an RCD510 today, along with a sub/amp, but I just wondered, do I need to 'code' anything using VCDS? As I get a rumbling from the sub when I turn the car on, took it to a car audio place, he just said the amp was quite fiery and turned the gain down on it and if it continues, disconnect the negative wires from the LOC.
But I just thought perhaps I need to 'tell' the system to expect the fact an amp and sub is connected? I know this needs doing with the dynaudio pack, so would this apply here?
Thanks in advance,
Sean
Re: Does the stereo need coding for an amp/sub (soundpack?)
« Reply #1 on: January 24, 2011, 09:46:21 pm »
no it won't need codeing..does it still do it now the gains are turned down
Offline SeanyK
  • -Given: 35
« Reply #2 on: January 24, 2011, 09:51:31 pm »
Long story short, I fitted it all bar the ignition live, I did ask him to check the LOC and he said he connected the earth wire from the LOC as I hadn't done that.
He then said the amp was behaving fiery, so he turned the gain all the way down and said it should be ok but keep an 'ear' out for it going over-the-top sound wise.
Basically if I go and sit in the car now, I will turn the ignition and hear a rumble from the sub.
I haven't touched any gains in the RCD menu though I must admit...
Offline Modz
« Reply #3 on: January 24, 2011, 09:55:50 pm »
check the remote wire conection or try running the phono leads on the other side of the car away from the power cable if you aint allready done so
Offline SeanyK
  • -Given: 35
« Reply #4 on: January 25, 2011, 08:31:51 pm »
Best way to describe it.
Is when the radio is turned on, I get a 'heartbeat' sound from the SUB for about 2 seconds, like the woofer itself is flexing back and forth.
« Reply #5 on: January 25, 2011, 09:21:56 pm »
sounds live its getting a direct live feed have you got a power cap in your system
Offline SeanyK
  • -Given: 35
« Reply #6 on: January 25, 2011, 09:27:50 pm »
No power cap no?
It's this;
http://www.alpine-electronics.co.uk/products/details/powered-subwoofer-boxes/swe-1000.html
Not the greatest in the world.
It didn't do it when I had an Alpine head unit though... Only since swapping to the RCD
Offline GLIDN
« Reply #7 on: January 25, 2011, 09:29:26 pm »
It's possible it can either be your LOC causing the issue.
Otherwise there is a remote chance it can be your amp or wiring.
Offline SeanyK
  • -Given: 35
« Reply #8 on: January 25, 2011, 09:33:59 pm »
I think the problem with the Alpine amp/sub is that it uses one of those connector blocks, so unlike the usual Amps and subs, where you run seperate wires, this one is all in one lead.
The power cable is quite thin too compared to the usual Amp power cables.
I might take it to local car audio place and see what they say, although I can see myself asking them to just sort it out and put decent speakers in! I've spent enough... Argh! :grin:
« Reply #9 on: January 25, 2011, 09:37:28 pm »
think the rcd doesn't have a remote wire (blue) so you have to wire the acc wire from your ignition so this might cause the problem
Offline mortygttdi
  • -Receive: 146
« Reply #10 on: January 27, 2011, 03:07:13 pm »
If you are using the any of the oem speakers or running the amp through the headunit at all then you need to code the stereo for the sound pack.
Darren
Offline SeanyK
  • -Given: 35
« Reply #11 on: January 28, 2011, 07:29:57 pm »
Darren
...Interesting, thanks Darren will give this a shot tommorow! At one point I saw Radio (Analogue) and Radio (Digital) the analogue was checked, I take it thats correct?
I will code the radio for soundpack.
« Last Edit: January 28, 2011, 07:36:22 pm by SeanyK »
