Author Topic: Diesel Equivalent to ED30 Anyone?  (Read 11535 times)
Re: Diesel Equivalent to ED30 Anyone?
« Reply #60 on: January 27, 2011, 10:04:25 pm »
I did Devon Mikey Boys brakes on the replacement car after his 450BHP 140PD, he sold it and bought a 550BHP twin turbo R32......
The biggest problem with Diesel tuning is that you have to spend some serious money on clutches - not an area you can scrimp on.....
One of the lads on the Mk4 forum is running a 260BHP big turbo 150 Engine with a V6 Long legged gearbox and in gear it would keep up with a Stage 2 ED30 I would say fairly easily, he uses it as a daily and gets 50+ MPG, totally effortless driving as well
not for getting Bob Singh arl engine 300bhp with 530 nm of torque
http://uk-mkivs.net/forums/t/397746.aspx?PageIndex=1
« Last Edit: January 27, 2011, 10:06:34 pm by maxitrol »
Offline White_Lady_170
« Reply #61 on: February 07, 2011, 01:06:50 pm »
Our stage 3 2.0 PD makes 240-260 bhp and 400 ft/lb but you need:
Intercooler
Flywheel (uprated dual mass)
Uprated clutch kit
Turbo back exhaust system
Stage 2 hybrid turbo
EGR removal
Solid boost pipes
PDT stage 3 custom map.
Did one at the end of last year that made 261hp and 380 ft/lb without the egr removal and solid boost pipes but time will tell if the original crappy plastic ones will last.
Very very quick in a straight line, suprisingly quick infact and holds power to 5400 rpm, will outpace a lot of cars you wouldnt expect.
Would you have anymore info or links to this?
Is it a 140PD or the 170PD engine?
I'm currently running stage 2 on a PD170 Leon FR, approx 225bhp and 360lb/ft, looking into the next stage as i've got used to the power already! :(
Offline PDT
  • -Receive: 142
« Reply #62 on: February 07, 2011, 06:48:56 pm »
Thats based on the 140pd
The 170 will make similar figures with the right clutch and turbo.
Offline tmagnet
« Reply #63 on: February 07, 2011, 06:55:36 pm »
Hi,
Was it using uprated injector nozzles or was it still on the standard injector/nozzles?
« Reply #64 on: February 08, 2011, 12:54:44 pm »
Yes, clutch upgrade, turbo, I will need convincing...
My FR was mapped by a tuner who had himself, an FR. On his own car he experimented with different maps and setups, including running a hybrid turbo. His own words were for the cost of a hybrid turbo, he would not do it again as the gains were far from worthwhile.
Is it not a case, that the standard injectors on the 170PD max out at in and around the same sort of figures (bhp) as what a few people are achieving after DPF removal and stage 2 software?
by "right turbo" can you elaborate any? Are we talking hybrid as above or a completely different unit...?
thanks
