Author Topic: Sunset Red 1.4 TSI(TFSI) GT Sport - daily drive & track car  (Read 348684 times)
Offline rex
  • -Given: 50
  • -Receive: 74
Re: Sunset Red 1.4 TFSI GT Sport - daily drive & track car
« Reply #450 on: June 17, 2012, 06:48:36 pm »
Yup, I intend to solve the issues but if not I will just go like the last trip (a little bit slower and changing at 6000 RPM).
I may have misled you. I am not sure it is Cylinder No 4. I only know I might have issues on one cylinder but I am not sure yet which one.
« Reply #451 on: June 17, 2012, 07:53:31 pm »
Usually it has been cylinder 4 on the forums...furthest right as you look under the bonnet. :smiley:
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #452 on: June 19, 2012, 11:19:27 am »
I've cleaned my track wheels and tires and this is what I found:
I was really lucky because it did not cause a puncture. The screw is caught in the excess rubber collected from the track so no damage to the tire. I only went on the Hungaroring track so I am glad I collected this screw and not somebody actually racing over there.
This is one of the disadvantages of buying expensive track tires. If you manage to puncture them there are a lot of money lost...
« Last Edit: June 12, 2021, 09:54:03 pm by rex »
« Reply #453 on: June 19, 2012, 01:33:15 pm »
Are they your new Direzza's ! :surprised: i used to get quite a bit of tread beading with mine but not as much as that, i thought your car was a fair bit lighter than my GTI.
Perhaps i wasn't trying hard enough.  :rolleye:
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #454 on: June 19, 2012, 01:58:29 pm »
Well, It should be a little bit lighter than a GTI. But the rear should be identical...
Those are the rear tires and I always collect rubber with the rear tires. In fact, I have more rubber on the rear tires at the end of the track day than in the beginning  :evilgrin:.
Maybe you didn't push hard and the rear tires never got warm enough to collect a lot of rubber...
Anyway... I don't think this is a good indication of how fast we are going. It might be that there is not much rubber on the track for us to collect...
« Last Edit: June 19, 2012, 02:18:35 pm by rex »
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #455 on: June 25, 2012, 10:46:31 am »
So, as I said before I like to work on the car when I have the time and here is my last update...
Because of the rollbar installation there were some estetic issues. First of all the rear seats came off and I had to do something about the space. Second of all the interior was trimmed to acommodate the roll bar. These gaps had to be covered.
Here are some photos...
Before:
After:
Before:
After:
As you can see now I have a very big trunk  :innocent:.
Unfortunately I could not make the trunk at the same level because the piece sitting where the back seats sat is taken from a friends S3 (Adrian since some of you know him) and the S3 has a higher trunk due to the 4WD system. I trimmed the piece but this is as low as I could get. Anyway, this is good enough for me...
Before:
After:
Before:
After:
As you can see the carpet is not closed around the rollbar because I still want access to the rollbar nuts and bolts. I will probably use some velcro to bring the two pieces closer together.
So one step closer to having the car just the way I like it  :smiley:.
Comments are welcomed and thanks for watching!
 :drinking:
« Last Edit: June 12, 2021, 09:58:17 pm by rex »
« Reply #456 on: June 25, 2012, 10:56:46 am »
Fantastic touch Vlad  :congrats:
« Reply #457 on: June 25, 2012, 11:37:17 am »
Nice work. It is the finishing touches that make a car. :happy2:
Offline Fcan_PT
« Reply #458 on: June 25, 2012, 11:40:24 am »
Great job!  :congrats:
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #459 on: June 25, 2012, 11:46:25 am »
Thank you very much guys!  :ashamed:
 :notworthy:
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #460 on: June 25, 2012, 12:26:30 pm »
Superb mate  :congrats:
Love your attention to detail. Keep up the good work  :notworthy:
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #461 on: June 25, 2012, 01:03:54 pm »
Thank you  :notworthy: !
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #462 on: June 29, 2012, 07:25:22 am »
So, yesterday the tests were finally finished. Spark plugs are ok, injectors are ok, camshaft is ok.
But, the mechanic found some issues when measuring the cylinders compression:
Cylinder No1 - 7,5 bar (I think bar is the measuring unit)
Cylinder No2 - 10 bar
Cylinder No3 - 10 bar
Cylinder No4 - 9,5 bar
So it looks like the valves (at least at Cylinder 1 and 4) are not working ok. I will clean them as soon as possible and than redo the test.
Offline fuscobal
  • -Receive: 27
« Reply #463 on: June 29, 2012, 09:50:47 pm »
Took a look today with my mechanic in VW technical papers and it seems a difference of 3bar between cylinders is accepted !?!? That's quite weird so I read it 2 times to be sure !
Mk5 GTI 6MT - Revo stage 3
« Reply #464 on: June 30, 2012, 12:04:20 am »
Any guidelines as to what pressure they should be running. I'm sure when I had mine tested they were 175-180psi = 12.4bar  but it may be that mine run a higher pressure than yours?
