Author Topic: VW tools for changing Syncromesh in GTI gearbox?  (Read 4425 times)
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« on: January 27, 2011, 03:34:11 pm »
Anyone know the tool numbers for the tools required to rebuilt a O2Q gearbox??
A bit urgent please  :drinking:
Over the top mod list ;o)
Offline vRSAlex
  • -Receive: 253
Re: VW tools for changing Syncromesh in GTI gearbox?
« Reply #1 on: January 28, 2011, 08:24:36 am »
I do have the numbers, but how deep is your wallet?  You will need to budget around £800 for everything needed iirc.
Follow AKS tuning on Facebook
  • -Given: 243
  • -Receive: 154
« Reply #2 on: January 28, 2011, 08:45:12 am »
Well, for starters i need the numbers, i might be able to borrow them, otherwise the wallet has to be used  :happy2:
Offline vRSAlex
  • -Receive: 253
« Reply #3 on: January 28, 2011, 12:42:09 pm »
Which syncro on what gear are you wanting to change?  I can get the correct part numbers for just doing that gear.
  • -Given: 243
  • -Receive: 154
« Reply #4 on: January 28, 2011, 12:59:23 pm »
Hi Alex,
I'm sorry i didn't get to catch you, and i'm sorry if i was to forward.
I'm changing them all, all the syncromesh, bearings and seals are being changed.
Thx for your time  :drinking:
Offline vRSAlex
  • -Receive: 253
« Reply #5 on: January 28, 2011, 01:06:58 pm »
Only a few things your changing then!!!
This is the list I have for all the genuine tools:
Pressure plate VW 401
Pressure plate VW 402
Punch VW 407
Punch VW 408 A
Punch VW 412
Tube VW 415 A
Holding plate VW 309
Holding fixture VW 313
Transmission support VW 353
Thrust piece VW 431
Thrust piece VW 433
Thrust piece VW 454
Thrust piece VW 512
Tube VW 516
Tube VW 519
Slide hammer VW 771
Holding plate VW 801
Thrust piece 40-105
Seal driver-front wheel bearing 40-20
Seal driver-front wheel bearing 40-21
Thrust piece 2050
Spacers VW 540/1 B
Taper roller bearing puller V.A.G 1582
Attachment V.A.G 1582/7
Internal puller Kukko 21/7
Internal puller Kukko 21/8
Puller Kukko 18/2
Separating tool Kukko 17/2
Support Kukko 22/2
You may not need the transmission stand if you can get a box out normaly.
  • -Given: 243
  • -Receive: 154
« Reply #6 on: January 28, 2011, 01:17:03 pm »
Punch VW 407
Punch VW 408 A
Punch VW 412
Tube VW 415 A
Thrust piece VW 431
Thrust piece VW 433
Thrust piece VW 454
Thrust piece VW 512
Tube VW 516
Tube VW 519
Slide hammer VW 771
Thrust piece 40-105
Thrust piece 2050
Spacers VW 540/1 B
Puller Kukko 18/2
Support Kukko 22/2
This is more than excellent. I'm sorry i didn't catch you on the phone, hopefully you are going to GTI International, i owe quite a few of you very helpfull gents a pint  :drinking:
