Author Topic: Can a GTi do 300+ km/h ? This one can  (Read 3582 times)
Offline Rich
    • Carpet Underlay
« on: January 29, 2011, 09:32:50 pm »
Fast forward to 0:34
Offline RobH
  • Revo stg 2+
Re: Can a GTi do 300+ km/h ? This one can
« Reply #1 on: January 29, 2011, 09:50:14 pm »
I think you've answered your own question there Rich :rolleye:
Saint Steve
« Reply #2 on: January 29, 2011, 10:27:57 pm »
With a tyre warning light on aswell............TW&T comes to mind :fighting:
Offline Rich
    • Carpet Underlay
« Reply #3 on: January 29, 2011, 10:40:46 pm »
But i'm sure i read the pistons/ gearbox nor the body shell couldn't hope with such speed?
« Reply #4 on: January 29, 2011, 11:09:36 pm »
WIth enough horsepower it probably can but I'm not sure I would like to be behind the wheel.  :scared:
Offline Janner_Sy
  • -Receive: 113
« Reply #5 on: January 29, 2011, 11:15:07 pm »
its restricted by the gearbox and the standard rev limits though, so to pull of that speed id bet it needs loads of uprated internals to allow it to rev alot higher
« Reply #6 on: January 29, 2011, 11:24:57 pm »
I've had 168mph out of mine with the GPS. The speedo was off the needle too at over 180. :laugh:
Depends how inaccurate the speedo is at a guess. I reckon that clip was a solid 170mph on a GPS, which would put the needle off the end of the speedo :driver:
« Reply #7 on: January 29, 2011, 11:40:06 pm »
In 6th it will pull 27mph per 1000rpm so the maths is fairly straightforward.  :wink:
Offline vRSAlex
  • -Receive: 253
« Reply #8 on: January 30, 2011, 10:28:34 am »
My old Ibiza pulled 172mph gps.  I would have thought most 2+ cars could pull 160mph +?
Follow AKS tuning on Facebook
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #9 on: January 30, 2011, 11:15:10 am »
Even true 420 HP is not enough for a speed of real 300 km/h with a Golf.
You have to drive a hill down to reach this speed. Next problem: gearbox and rpm.
"You get what you pay for."
Offline laurent.d
« Reply #10 on: January 30, 2011, 11:56:38 am »
I had about the same downhill on the German autobahn. I remenber, even if I realy had to focus on my driving, that I saw 275km/h (about 172mph) at the GPS and the car was still going a little bit faster. Then I saw 7200rpm on the tachometer in 6th gear that is about 290km/h (180mph) at the speedometer. That's bloody fast even more on a bumpy two lane higway, with curves!!!  :driver:
My car is about 300Hp
That said, I made some simulation based on real A3 speed recorded with several type of engine ans it seems that maximum real speed achievable with an A3 on flat road is:
300Hp => about 260km/h 160Mph
350Hp => about 270km/ 170Mph
400HP => about 280km/h 175Mph
To reach 300 real km/h 190Mph you will need about 600Hp!!!
A3 2.0 tfsi DSG S-Line/VWR K04 Turbo kit/Engine Revo Stg 3/Milltek Exhaust/DSG Revo Stg 2/Quaife LSD/Bilstein PSS10/H&R sway bars/Power Grip Morego/VWR Suspension Bushes/VF Engineering Engine Mounts/VWR Lower Mount/OZ Ultraleggera 8x18 ET45/Brembo 328x28 2pcs 4 pot ''A'' caliper/Braille Battery
Offline S2 Ant
  • -Receive: 21
« Reply #11 on: January 30, 2011, 03:57:57 pm »
Ah Mihnea working his magic as usual by the looks of it
Ant
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #12 on: January 30, 2011, 03:59:48 pm »
186mph gps verified in a stage 2 TTRS.
194mph in a 470hp TTRS with raised limiter.
« Reply #13 on: January 30, 2011, 04:40:12 pm »
:drool:
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #14 on: January 30, 2011, 06:22:06 pm »
:drool:
Your s-tronic in 7th, can get you up to 240mph iirc, if you have enough power. Dont think even I would be crazy enough to try that though  :signLOL:
