Author Topic: Anyone in the Uxbridge area??  (Read 3056 times)
Offline johnhol78
Re: Anyone in the Uxbridge area??
« Reply #15 on: January 31, 2011, 01:17:58 pm »
Personally, i'd check a dealer price first and if poss a TPS at a dealer as its going to be possibly cheaper for the same item.
But if you think something is up i'd check that first, as if there is nothing wrong then its money being spent for nothing
What do you mean my a TPS at a dealer?
Would be able to pop up one night this week if possible.......off today but let me know when would be best.
Offline MattPoss
« Reply #16 on: February 01, 2011, 06:05:10 pm »
TPS = Trade Parts Specialists
http://www.thetradepartsspecialists.co.uk/
Matt
Offline johnhol78
« Reply #17 on: February 01, 2011, 06:19:10 pm »
Matt
Worked it out and went tonight....bought and ready to fit.
kierongti
« Reply #18 on: February 02, 2011, 06:55:06 pm »
my gti wasnt boosting properly and hissing alot. turned out to be the dv.. i changed it for the revised vw part. boosts lovely now. i am in aylesbury by the way.
when u take dv off the car its only 3 screws and a plug if i remember correctly. once off have a look inside the black plastic casing and you will see a rubber stretchy type material, lol... that tends too perish over years and develops holes in it where the boost escapes. got my old dv here to prove it..  :jumpmove:
Offline robdf2
« Reply #19 on: February 02, 2011, 07:42:39 pm »
im in twickenham area mate with vagcom , i have my daughters this weekend but you are more than wellcome to drive over and i will scan your car for you and if time might log your boost as well.
Rob.
2008 Chrono yellow Cupra
Offline johnhol78
« Reply #20 on: February 03, 2011, 01:16:11 pm »
Rob.
That would be ideal.....especially the boost logging....
Hopeing to fit the DV tomorrow night or Saturday morning so if things don't imporve I'll give you shout if that's ok..
Offline robdf2
« Reply #21 on: February 03, 2011, 01:17:51 pm »
yep thats fine mate.
Offline johnhol78
« Reply #22 on: February 04, 2011, 05:06:02 pm »
Started the job of changing my DV.
Loosened the wheel nuts, jacked it up and had the axle stand ready........flaming jack wouldn't lift the car high enough to get the axle stand under the rear wishbone joint....AAARRRGGHHHHHHHH
So wheel back on, lowered the car and packed it all away, will have to rethink the strategy a bit more and start again in the morning...
 :sad1: :sad1: :sad1: :sad1: :sad1: :sad1:
