Author Topic: Canbus Upgrade For An RNS510  (Read 5104 times)
Offline bodger00
  • -Receive: 20
  • A wish called Zonda
« on: January 30, 2011, 08:45:20 pm »
I am not too sure I understand the naming on these??
For example to ensure the battery drain issue does not occur you would need to get an L revision or greater.
Then I read if you get an AF canbus then that is the latest.
L , AF I am confused :ashamed:
Can anyone shed some light in this?
I know I would need one as I have an 06 plate.
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: Canbus Upgrade For An RNS510
« Reply #1 on: January 30, 2011, 08:50:04 pm »
L with only one letter, after that revision range they starter using 2 letters, you know like 5 and 13, 13 is after 5  :wink:  :grin:  :drinking:
Over the top mod list ;o)
Offline apollo13
  • -Receive: 47
« Reply #2 on: January 30, 2011, 09:03:46 pm »
Imagine A to Z then after that AA to AZ
So AA is after Z
Therefore AF is newer than AD and AD newer than L
Offline bodger00
  • -Receive: 20
« Reply #3 on: January 31, 2011, 01:19:37 pm »
Ah that's how they do it then. Fair enough. Obviously A isn't after L so hence the confusion. Don't want to be buying an old one just to find it doesn't work.
« Last Edit: February 01, 2011, 06:45:36 pm by bodger00 »
Offline Kalpsn2000
  • -Receive: 56
« Reply #4 on: January 31, 2011, 11:29:30 pm »
I upgraded to the RNS 510 version C LED just over a week ago and had to upgrade the can bus also (my 2007 (56 plate) had a can bus version K).
As you will have to upgrade the can bus you may as well get the latest version, AF.
Offline apollo13
  • -Receive: 47
« Reply #5 on: January 31, 2011, 11:49:27 pm »
Only if your buying it new. If you can't find an AF secondhand/cheap than many others will do
Offline Kalpsn2000
  • -Receive: 56
« Reply #6 on: February 01, 2011, 11:16:17 pm »
Yes any can bus L or later will do as the op seems to know.
But this is the one I went for:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=320619969121&viewitem=&sspagename=STRK%3AMEWNX%3AIT
Great price I thought :happy2:
Offline apollo13
  • -Receive: 47
« Reply #7 on: February 01, 2011, 11:27:14 pm »
 :stupid:
Offline Kalpsn2000
  • -Receive: 56
« Reply #8 on: February 02, 2011, 09:57:26 am »
 :stupid:
Ok no need to be like that.
I was just helping the op find the AF at a good price :happy2:
Offline bodger00
  • -Receive: 20
« Reply #9 on: February 02, 2011, 01:23:04 pm »
What was the service like from that seller? Are they truly new?
Offline Kalpsn2000
  • -Receive: 56
« Reply #10 on: February 04, 2011, 01:38:38 pm »
The seller has 100% feedback and I have to say he/she deserves it.
I opted for Standard international shipping as half the cost of UPS and it was sent by TNT. Took 3 working days to arrive and worked fine.
It is listed as ‘new’ but not sure if it is. Came in a bubble wrap bag in an envelope, not retail packaged, so most likely used but no marks on it.
These are about £150 from the dealers; I got it for £68 so even if its used I’m happy.
« Last Edit: February 04, 2011, 02:04:00 pm by Kalpsn2000 »
Offline bodger00
  • -Receive: 20
« Reply #11 on: February 04, 2011, 07:07:45 pm »
Cheers :happy2:
Offline xxx_mojo_xxx
  • MUBster DUBster
« Reply #12 on: May 06, 2011, 06:34:10 pm »
Just to confirm, whats the latest revision and ETKA number?
Also, will the replcement need to be programmed to work with all the options, e.g. Satnav, climate control, etc.
Thanks in advance.
  • -Given: 243
  • -Receive: 154
« Reply #13 on: May 06, 2011, 07:15:40 pm »
Latest i have seen is AH which i have myself, and yes needs to be coded with the info from the old one, so write it down or prntscrn the info before you take the old out  :happy2:
  • MUBster DUBster
« Reply #14 on: May 06, 2011, 08:37:22 pm »
Thanks, So how do I go about examining the previous settings?  Will it be in the VCDS read outs?
