Author Topic: Help needed coding rns510 and highline  (Read 3775 times)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=99atho0rm4p9ptth6ig4e9apag&/topic,19740.0.html
Re: Help needed coding rns510 and highline
« Reply #15 on: February 04, 2011, 11:39:39 pm »
My explanation was better though as i reminded you to code the RNS too.
I'm branching out in to Mapping now. If you can map cars but not know how to use VCDS then I will sh*t hot at mapping as i can use VCDS  :laugh: :booty:
:booty:
« Reply #16 on: February 04, 2011, 11:52:57 pm »
:signLOL:
Offline PDT
  • -Receive: 142
« Reply #17 on: February 05, 2011, 12:07:07 am »
when you get stuck, feel free to ask for advice  :innocent:
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #18 on: February 05, 2011, 12:09:55 am »
I will. I'm sure I've got Custard Codes no. somewhere :P
Offline PDT
  • -Receive: 142
« Reply #19 on: February 05, 2011, 12:16:09 am »
Feed me
 :signLOL:
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
« Reply #20 on: February 05, 2011, 09:26:55 pm »
Don’t know if this helps but this is the coding on mine, will be slightly different as the box for the reverse camera is ticked which will alter the code. Hope this helps.
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway   H07 0052
   Revision:   H07 01    Serial number: 100907F1001462
   Coding: ED817F064002020003
   Shop #: WSC 01279 785 00200
   VCID: 3065F88ADAA5
No fault code found.
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 C    HW: 1T0 035 680 C
   Component: RNS-MID       H04 2680
   Revision: AB001001    Serial number: VWZ6Z7J9320057
   Coding: 080100400100001200
   Shop #: WSC 05314 000 00000
   ASAM Dataset: ------------------------- ------
   VCID: 2E59E6F2C091
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
   VCID: 2E59E6F2C091
MFSW + Highline + RNS 510
« Last Edit: February 05, 2011, 09:29:52 pm by StephenED30 »
Offline PDT
  • -Receive: 142
« Reply #21 on: February 06, 2011, 05:27:58 pm »
Thanks richwig, vrscarl and stephened30
Got it sorted  :happy2:
