Author Topic: Drivers Door not Locking With Remote  (Read 1818 times)
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« on: February 05, 2011, 05:42:21 pm »
Anyone come across this before:
The drivers door wont lock via the remote, all the others do.  It does lock fine using the blade.
It unlocks no problem with the remote but there is a slightly different noise than usual?  Tried dousing inside the barrel with WD40 and the bits I can see via a little rubber gromit in the side of the door.
Any pointers welcome.
« Last Edit: February 05, 2011, 11:01:26 pm by ub7rm »
Sepang Blue S4 BE Avant
Offline gti_jim
Re: Drivers Door not Unlocking With Remote
« Reply #1 on: February 05, 2011, 08:02:44 pm »
I had a similar problem recently - it wouldn't unlock on the driver's side with the remote, just with the key. It started temporamental and got worse. Diagnosed as driver's door lock actuator needing replaced - £100 for the part, same in labour at an Indie. £345 at the Stealers.
« Last Edit: February 05, 2011, 08:04:33 pm by gti_jim »
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #2 on: February 05, 2011, 10:09:11 pm »
Fiddlesticks  :sad1:
Ah well, easy come easy go  :grin:
