October 04, 2024, 09:28:29 pm
All Things Mk5
Mk5 General Area
Drivers Door Outer Skin
Topic: Drivers Door Outer Skin (Read 1028 times)
ub7rm
Won't Shut up.
-Given: 35
-Receive: 43
February 06, 2011, 03:06:13 pm »
Any one removed the outer door skin before? I think I'm going to have a crack at changing the door lock module on the drivers door of my car and from TT's workshop guides it seems you do this by taking the outer skin off. Which seems reasonably simple - but is it?
Do you have to take the door card off from the inside as well? Doesn't look as if you do ...
Sepang Blue S4 BE Avant
Eddie-NL
Trader - 2014
Just look at my post count
-Given: 0
-Receive: 298
My Ride:
Re: Drivers Door Outer Skin
Reply #1 on:
February 06, 2011, 07:42:39 pm »
see your other thread, I have posted a link on how to remove the outer skin
If you are changing the the lock you will need to take the door card off too
Last Edit: February 06, 2011, 07:51:31 pm by Eddie-NL
Genuine VCDS VAG-COM HEX-USB + Genuine Vag Commander + Genuine VAG Tacho + Genuine VAG CAN PRO + RNS Manager for Video in Motion and New Pin Code for RNS510
Cluster and Key coding
Location Great Yarmouth
All Things Mk5
Mk5 General Area
