Author Topic: Michelin Pilot Super Sport (235/35-19" 91Y) treadwear 300 Review  (Read 38524 times)
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« on: February 06, 2011, 08:02:34 pm »
Well i'm getting a bit ahead of the game here but wanted to gather info about this tyre as i can see it be a preferred tyre for the Mk V GTI in the high end tyremarked.
Some reviews from the net:
http://www.porscheblogs.co.uk/tested-the-new-michelin-pilot-super-sport/
http://www.roadandtrack.com/special-report/review-michelin-pilot-super-sport-tires
http://www.carmagazine.co.uk/Drives/Search-Results/First-drives/Michelin-Supersport-2010-tyre-review/
http://www.tyrereviews.co.uk/Article/The-Michelin-Pilot-Super-Sport-has-arrived.htm
As i have only gotten the tyres fittedmy review will come later, but as a tyre for everyday use with grip and mileage in mind it does look promising  :happy2:
Over the top mod list ;o)
Offline laurent.d
Re: Michelin Pilot Super Sport (235/35-19" 91Y) treadwear 300 Review
« Reply #1 on: February 07, 2011, 07:28:02 am »
It's a pity they are not available in 225/40/18!! :confused:
I will stick with my Pirelli P ZERO MO. :happy2:
A3 2.0 tfsi DSG S-Line/VWR K04 Turbo kit/Engine Revo Stg 3/Milltek Exhaust/DSG Revo Stg 2/Quaife LSD/Bilstein PSS10/H&R sway bars/Power Grip Morego/VWR Suspension Bushes/VF Engineering Engine Mounts/VWR Lower Mount/OZ Ultraleggera 8x18 ET45/Brembo 328x28 2pcs 4 pot ''A'' caliper/Braille Battery
  • -Given: 243
  • -Receive: 154
« Reply #2 on: June 29, 2011, 07:39:08 pm »
Right,
I have now had these tyres for app. 2 month and as for daily use i have not found any downsides, they are excellent in the rain not noisier than other tyres i have tried and they have been used at Knutstorp race track which is a very twisty and tyredemanding track. They have also been on a roadtrip to Inters and a evening session at Donnington in 28degrees heat.
At Knutstorp the temp. was app. 20 degrees and they performed well and was very predictable in their caracter with 35psi cold front and rear. half the day the rain poored down with my Autotech rear ARB sat to medium i had four incidents where i had RWD caracter on the car and on the fifth incident i made a mistake and lost it. These incidents are down to the stiffer rear ARB rather than the tyres.
On Donington i tried going 20psi front and 18psi rear, this was way to low and i went for 40psi front and 25psi rear hot, which gave some predictable slips and made me able to haul stripped BMW's and Clio cup cars in even in the turns.
As i'm no tyre expert here are som shots of the tyres after Donington and the high pressure runs.
Offline animal
  • .:R32
« Reply #3 on: June 30, 2011, 09:41:21 am »
I'm sticking with PS3s, I can't justify the extra cost and I'm not one for skimping on tyres either. A Golf just doesnt warrant tyres that we designed for 911 Turbos and 599 GTOs. I'm just about to replace my first full set of PS3s and whilst they've not out lasted the ContiSportContacts they replaced (Contis always seem to be hard and noisey), they are much much better tyres in every other respect.
A lot of forum waffle seems to suggest that the PSS is the replacement for the PS2 when in actual fact, the PS3 it the true successor. The PSS is a completely new, high-end tyre as the PS2 was too compromised trying to cater for GTIs and GTOs.
I'm not disputing that the PSS isn't a great tyre, all the reviews I've read suggest that they even better than the PS3, which means they must be good. For road driving though, the PS3 is more than adequate - wet grip it supposed to be massively improved over the PS2. Even Michelin state they are intended for sports car and high power saloons, so if they're good enough for an M3/M5 - it's good enough for me. For the track, I'd use something more focused and track specific i.e. the PS Cup.
  • -Given: 243
  • -Receive: 154
« Reply #4 on: June 30, 2011, 12:29:52 pm »
I can't disagree with your point of view, just see the PSS as 2 tyres in one, i drove from Denmark to the UK, car was on display at Revo stand Inters and the day after i went to a track day at Donington, kept up with BMW's stripped for track use and went back to Denmark, that's the tyre the PSS is. We were 3 persons including luggage for the trip, that wouldn't have been possible if i had had to bring track day tyres and extra rims in the car.
The tyre is that confident inspiring that i didn't hold back at Donington at any time, the brakes was the ones to go first, smoking like h**l and leaving deposits all over the disc  :surprised:
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #5 on: June 30, 2011, 06:22:43 pm »
The PSS surely will be my next 19" road tyre when the Conti SC3 are worn.
I first had the PS2 on my GTI and I'd never buy the PS3. Like others on this
forum I'm more sports oriented and so I prefer stiffer kind of tyre providing
good steering feel (like PS2, PSS, SC 5P or P Zero).
"You get what you pay for."
Offline jon-tfsi
  • -Receive: 27
« Reply #6 on: June 30, 2011, 08:56:42 pm »
I will deffinately be considering a set of these when the R1R's wear out . . . . . which should not be too long the way they scrub off LOL.
Its amazing the amount of difference a tyre can make to the way the car feels
The Mk5 platform cars can feel very numb through the steering but going for a better tyre can improve this no end.
How would you compare them to the R1R's from a steering feel point of view Jake??
The R1R's make things feel much more lively on turn in, however they have a very soft sidewall and on really tight corners you can feel them rolling and letting go.
Are the sidewalls stiffer on the PSS?
GOLF R Mk7
  • -Given: 243
  • -Receive: 154
« Reply #7 on: June 30, 2011, 09:12:40 pm »
The PSS feels stiffer, might be down to them for my feeling running 40psi front warm, they are confident giving in the corners, the dual compound rubber gives a similar grip when cornering hard as the R1R has, but after the 16 of august i will be able to better comment as i then goes on track with the R1R's. I'm no expert but i didn't held back using the PSS even though they were a "roadtyre". So for the best of both worlds this is the one. :happy2:
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #8 on: August 20, 2011, 03:13:29 pm »
I dont agree with this.
PSS tyres where designed to reduced understeer and do so brilliantly. Wet grip is massive, dry grip is massive. My TT had ps2's before the PSS and the PSS is superior in every way. PSS also costs basically the same as the ps2 from good retailers. PSS also last longer.
I read that the ps3 isnt the ps2 sucessor btw, infact iirc some pss articles mention that the pss is the ps2 sucessor and not the ps3.
On the road the pss is better than the r1r's I tried, on the track the r1r's are superior. I believe the r1r's also give better steering feel.
Offline Poverty
  • -Given: 36
  • -Receive: 21
« Reply #9 on: August 20, 2011, 03:18:14 pm »
Just to add, of all the TTRS owners that have had PSS fitted, we have all said it has transformed the handling, the inherent understeer is gone, the car handles pretty much neutral now.
Offline Squips
« Reply #10 on: November 16, 2011, 03:50:43 pm »
How much does these cost?
  • -Given: 243
  • -Receive: 154
« Reply #11 on: November 16, 2011, 03:51:53 pm »
I bought mine from Tyretraders.co.uk, around 1000£ for 4 shipped  :wink:
Offline WhiteGTI
  • F-A-S-T
« Reply #12 on: November 16, 2011, 06:03:43 pm »
This is exactly as I was told by Michelin themselves.
2006 E46 BMW M3 - 343hp
Offline Squips
« Reply #13 on: November 16, 2011, 06:40:15 pm »
eeeeeeeeeeeeeeeeeeeeek
  • -Given: 243
  • -Receive: 154
« Reply #14 on: November 16, 2011, 07:28:24 pm »
over the last 2 years i've used more than 2700£ on tyres  :grin:
I never compromise on tyres or brakes, learnt that riding motorcycles for many years  :wink:
