Author Topic: Bluetooth Phone Install Problem  (Read 18855 times)
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Bluetooth Phone Install Problem
« Reply #15 on: February 14, 2011, 07:08:23 pm »
I have -
1 V+ to pin 16
2 V- to pin 12
3 Telephone ON
8 Audio LF Signal out + connected to be connected to pin 12 con 3
9 Audio LF Signal Out - connected to be connected to pin 6 con 3
10 Screening Term 31
11 Mic in +
12 Mic in -
15 K Line
16 Mute
17 CAN Hi to pin 9
18 CAN Lo to pin 10
37 Switched positive term for phone charging
39 Term 31 -ve
41 Interface to mob phone Term 30
42 Mic Out +
43 Mic out -
44 Screening Term 31
45 Audio LF Sig input +
46 Audio LF Sig Input -
47 Wakeup lead to phone bracket
49 Serial Tx comms with tele bracket +ve
50 Serial Tx comms with tele bracket -ve
51 Serial Rx comms with tele bracket +ve
52 Serial Rx comms with tele bracket -ve
Stu...
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
« Reply #16 on: February 23, 2011, 08:01:22 pm »
Thanks for all the help so far, I ended up buying this
http://cgi.ebay.pl/ws/eBayISAPI.dll?ViewItem&item=180605717424
as could not figure out the wiring. When I checked this to the loom I had it turned out that the existing loom only had a plug with 2 rows of connections on where the one from e-bay had 3, only 1 wire on the third row at position 41 Interface to mob phone Term 30 (may be wrong but will check later). Have now fitted the new loom into the car and have
Address 77: Telephone        Labels: 3C0-035-730.lbl
   Part No SW: 5N0 035 730 C    HW: 5N0 035 730 C
   Component: J412                8506
   Revision: 00019000    Serial number: 0000A07751228
   Coding: 0021141
   Shop #: WSC 00152 210 91233
   VCID: 285510EAE275
1 Fault Found:
01524 - Antenna for Telephone
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 233
                    Mileage: 37803 km
                    Time Indication: 0
Did some recoding and now have this
   Coding: 0013241
   VCID: 285510EAE275
Still have a couple of minor problems in that when I turn the ignition on the highline display will display Telefone and I can only transfer 1 name to the car from the phone address book but it will read all the messages. And on the phone screen on the RNS510 I have preset 1 as Mobile Box and cannot seem to change it in any of the settings.
« Reply #17 on: February 23, 2011, 08:13:50 pm »
I have that on my 7P6 phone controller. I think it's a feature  :wink:
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
« Reply #18 on: February 23, 2011, 08:25:20 pm »
Thanks for that, but can’t see the point of making it so that you cannot edit it like the rest.  :happy2:
Offline mortygttdi
  • -Receive: 146
« Reply #19 on: February 23, 2011, 08:25:49 pm »
What phone you using Steven?  the preset 1 is for the voice mail and can be preset with your chosen number by pressing setup and going into the telephone and then speed dial.
Darren
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
« Reply #20 on: February 23, 2011, 08:32:06 pm »
Hi Darren, just a old Samsung Tocco (SGH-F480). Just set Mobil Box so I can just phone home.
« Last Edit: February 23, 2011, 08:33:55 pm by StephenED30 »
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
« Reply #21 on: February 27, 2011, 01:45:11 pm »
Have now played with the phone settings and copied the address book to the sim card, gone to car and updated contacts and now have 45 names to scroll through. Just need to get the star button working correctly now, when I press it, it comes up on the RNS 510 as language not supported, must be to do with the coding?  :confused:
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
« Reply #22 on: April 24, 2011, 04:36:26 pm »
Been a while since I have done anything to this so this is an update. Have played with a few things and have now got the voice dialling to work when I press the star button on the steering wheel. Also have managed to get the star button on the sat/nav to work so that I can program the nav by saying new destination, media, radio etc. What I want to know is why the steering wheel star button when pressed will not control the sat/nav. If I press the star button on the sat/nav I can control everything. Hope this all makes sense.
Coding is as follows
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Component: J0527           036 0070
   Coding: 0013142
   Shop #: WSC 01279 785 00200
   VCID: 8103ED4EA199
   Part No: XXXXXXXXXXX
   Component: E0221           002 0010
No fault code found.
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 C    HW: 1T0 035 680 C
   Component: RNS-MID       H04 2680
   Revision: AB001001    Serial number: VWZ6Z7J9320057
   Coding: 080100420100001000
   Shop #: WSC 05314 000 00000
   ASAM Dataset: ------------------------- ------
   VCID: 2E59E6F2C087
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
   VCID: 2E59E6F2C087
   Coding: 0013242
   VCID: 285510EAE263
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #23 on: April 25, 2011, 07:46:56 pm »
Try - 0013202 in 77.
It might need tweaking again but I'm working from a different label file at the moment.  :happy2:
Stu...
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
« Reply #24 on: April 25, 2011, 08:02:19 pm »
Thanks for that Stu. Will give it a try a bit later. Updated the firmware from 2680 to 2760 and have now got a different problem to solve, reverse camera has stopped working.
Monday,25,April,2011,19:33:31:54527
VCDS Version: Release 10.6.4
Data version: 20110418
                Address 37: Navigation       Labels: 1T0-035-680.clb
Control Module Part Number: 1T0 035 680 C    HW: 1T0 035 680 C
  Component and/or Version: RNS-MID       H04 2760
           Software Coding: 080100420100001000
            Work Shop Code: WSC 05314 000 00000
              ASAM Dataset: ------------------------- ------ ()
                      VCID: 2E59E6F2C087
1 Fault Found:
02873 - Control Module for Back-Up Camera (J772)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 54
                    Mileage: 39607 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:29:59
Just sent a PM to SteveP about it as I’m sure someone on here has had the same problem, one step forward and one back.
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #25 on: April 25, 2011, 08:09:03 pm »
Have you got the reverse camera coded on the can gateway??
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
« Reply #26 on: April 25, 2011, 08:18:20 pm »
Took this at the last scan
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 62 72 77
VIN: WVWZZZ1KZ8W120078   Mileage: 39600km/24606miles
37-Navigation -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: Malfunction 0010
Have cleared all of the faults and the one with the camera is the only one that keeps coming back.
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #27 on: April 25, 2011, 08:19:03 pm »
Where did you get the firmware from?
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
« Reply #28 on: April 25, 2011, 08:21:39 pm »
Offline alexperkins
  • -Receive: 99
« Reply #29 on: April 25, 2011, 10:09:03 pm »
Does the reverse camera have a control module? You might need to change thlong coding to Backup Camera (low) installed
