Author Topic: Bluetooth Phone Install Problem  (Read 18819 times)
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
Re: Bluetooth Phone Install Problem
« Reply #30 on: April 25, 2011, 10:21:33 pm »
It’s installed as per this guide,
http://www.mk5golfgti.co.uk/forum/index.php/topic,10027.0.html
been no problem at all up until I did the firmware update. Have now taken the √ from the box under the 37 nav menu and fault code is now gone. Will see if I can check fuses tomorrow just in case one has blown, don’t see how though. Thanks for all the help.  :happy2:
Offline alexperkins
  • -Receive: 99
« Reply #31 on: April 25, 2011, 10:25:53 pm »
Firmware updates can remove coding.
This is the part I'm referring to
Quote
Open the Navigation (37) controller and select coding, then long coding helper, then in the forth block set bit 6 to on (shown as "Backup Camera Low"), close the long coding and saving the new coding. Reboot the RNS-510 by pressing the "<" & ">" & "i" button.
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
« Reply #32 on: April 25, 2011, 10:41:52 pm »
Thanks Alex, that’s where I have removed the √ from, the reverse camera is just showing a fault with the box √ and not displaying on the sat/nav. Hope that makes sense.
Offline alexperkins
  • -Receive: 99
« Reply #33 on: April 26, 2011, 07:34:53 am »
Ah I get ya. Interesting that. It could be a bug in the firmware thats causing that. There was a bug in 3810 that wouldnt let me code it to the gateway!
