Author Topic: ho do i find out my midline part no  (Read 1933 times)
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« on: February 13, 2011, 09:07:57 pm »
i am in the process of buying a highline , i have been told i need to match the part number with a 7. is there an easy way of finding the part number without taking the speedo out??
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline apollo13
  • -Receive: 47
Re: ho do i find out my midline part no
« Reply #1 on: February 13, 2011, 09:18:21 pm »
Scan with VCDS. If you don't have it it takes 20 secs to pull the cluster.
Offline DamoP
  • -Receive: 115
« Reply #2 on: February 14, 2011, 05:55:25 pm »
cheers , i dont. really?? i thought it was a steering wheel off job??
Offline apollo13
  • -Receive: 47
« Reply #3 on: February 14, 2011, 05:57:24 pm »
No mate,
Just lower the steering wheel to the lowest position and pull it as far is it will go.
Remove the trim infront of the cluster, undo the 2 screws and slide it out.
FYI you don't need to match your highline to your midline.
I had a 962 midline and replaced it with a 971 highline....
« Last Edit: February 14, 2011, 06:04:13 pm by apollo13 »
Offline parks
  • Red ED30 No. 1778 Detailing World member
« Reply #4 on: February 14, 2011, 06:47:28 pm »
No mate,
Then plug highline in, VCDS, and job done? Thought it was much harder than that!!
Standard: Rear parking sensors, Parrot Bluetooth
Retro fitted: MFSW buttons, RCD510, Boot pop, Black Monza II, Xenons, Audi jacking points, open fog light grills.
Offline apollo13
  • -Receive: 47
« Reply #5 on: February 14, 2011, 06:49:45 pm »
No mate,
No that is not how to fit a highline! Well its is but along with a bit of coding.
 The OP wanted to know how to get the part number of his existing cluster without using VCDS............
