Author Topic: installing pioneer f900bt  (Read 2047 times)
Offline deebow
« on: February 16, 2011, 08:49:12 pm »
hi
planning to install a f900bt and wire my sub up in the golf. now reading around ive compiled a list of what i need but just want to make sure read right
to fit the stereo and also have it controlled by the steering wheeel buttons do i only just need a connects adapter and a double fakra arial adapter?
or is there something ive missed
Offline Lyons
  • -Given: 18
Re: installing pioneer f900bt
« Reply #1 on: February 16, 2011, 09:46:43 pm »
I'm selling a double din fitting kit with wiring and aerial adapters required in the classifieds section.
Offline deebow
« Reply #2 on: February 16, 2011, 11:04:36 pm »
does it come with the connects adapter to get the steering wheels control to work?
if so id take that off you
thanks
Offline deebow
« Reply #3 on: February 16, 2011, 11:15:27 pm »
also is a 3m rca cable long enough to reach into the boot as seen this one on ebay thats flat so should be easier to fit
http://cgi.ebay.co.uk/Ixos-1003-300-3M-2-RCA-2RCA-Interconnect-/270673051156?pt=UK_Computing_CablesConnectors_RL&hash=item3f055efe14
Offline Lyons
  • -Given: 18
« Reply #4 on: February 17, 2011, 07:44:06 am »
thanks
It doesn't I'm afraid as I don't have MFSW.
You will need the rest of the bits in the kit to make an aftermarket unit fit though.
Offline Lyons
  • -Given: 18
« Reply #5 on: February 17, 2011, 08:41:06 am »
Can't reply to you email for sone reason.
Offline deebow
« Reply #6 on: February 23, 2011, 11:44:51 pm »
can someone confirm do i have to have a 3rd party fascia fitted or would the stereo just fit in like that as was planning to install everything tomorrow but seems that i might require a fascvia where as first i thought i wouldnt
Offline Lyons
  • -Given: 18
« Reply #7 on: February 24, 2011, 06:49:00 am »
Yes, as per my post you require a fascia surround, cage, ISO wiring adapter and aerial adapter.
Offline deebow
« Reply #8 on: February 26, 2011, 10:38:20 pm »
ended up getting the bits off a mate as seems it had a spare one in his garage. now tried fitting it but ive not got the metal bits that you attach to the cage to keep the tv in one place in the dashboard. does anyone know  what theyd call these as cant seem to find them being sold seperately
thanks
