Author Topic: 'product enhancement' (recall!) on some mk5 gti's  (Read 122413 times)
Offline dmac1969
  • -Receive: 21
Re: 'product enhancement' (recall!) on some mk5 gti's
« Reply #390 on: May 12, 2012, 02:41:06 pm »
How long has the ECU update been a part of the recall? I had my coilpacks changed last year , will they have done the ECU then or will it need doing this year? I didn't ask to get mine done , my dealer told me about it and booked it in to be done without me asking. I remember the MPG seemed poorer on the MFA for a few weeks afterwards , would this be because they wiped the memory while the battery was off?
Offline Baz300
« Reply #391 on: May 12, 2012, 04:54:43 pm »
There seems to be a lot of vw dealers that seem reluctant to do any "recalls" on cars
I can't understand why as the parts and labour charges will be covered by vw so they are turning away business because of lazy staff.
I hope anyone that has bad experiences with dealers especially with safety recalls reports it to vw.
Offline Frenzy
  • -Receive: 29
« Reply #392 on: May 15, 2012, 12:32:23 pm »
Finally got around to ringing my local stealers about this and according to their records the 2 recalls on the car have been done. They referred to the coil pack recall though as an ignition coil recall? Does this make sense?
Offline Mk5 GTian
  • -Receive: 37
« Reply #393 on: May 15, 2012, 12:35:17 pm »
Funnily enough, I did the exact same thing today, and got the exact same response, Ignition coil recall. I assume it's the coil packs :confused:
Offline Frenzy
  • -Receive: 29
« Reply #394 on: May 15, 2012, 12:42:19 pm »
I'm thinking about ringing up a different stealers just to be 100% sure but as the guy checked the system and confirmed both recalls have been completed for my vehicle i'm sure it was the coil packs done last march and it was simply the case of him calling it a slightly different name than we have been referring to it on here.
« Reply #395 on: May 15, 2012, 12:42:41 pm »
It is the coilpacks, Ian. They'll check all which are currently fitted in your car and replace free of charge all those according to version part numbers.
Offline Frenzy
  • -Receive: 29
« Reply #396 on: May 15, 2012, 12:48:06 pm »
Yep as Robin says, i just rang a different stealers to cross check and they confirmed that it had been done and of course gave the same date that the previous stealers had said  :happy2:
Offline Mk5 GTian
  • -Receive: 37
« Reply #397 on: May 15, 2012, 12:53:42 pm »
Thanks Robin.  :happy2:
Do you need to specify no software upgrades to protect the map? I've heard a few murmers on here about this  :confused:
Offline da_ansa
« Reply #398 on: May 15, 2012, 03:01:11 pm »
Just booked mine in on Friday  :happy2:
Happy days
« Reply #399 on: May 15, 2012, 03:12:52 pm »
....An official VW software update usually overrides your aftermarket remap and it's wise to have a VW update if your car shows up as being eligible as it may solve important issues or prevent them from happening. Your aftermarket remap isn't lost, it's just 'buried' and will need restoring either by your tuner or a switch (if you have Revo). Tuners are obliged to see proof of purchase if they don't already know you and may charge a nominal fee of ~£25 to cover their time.
To the best of my knowledge VW haven't released a software update for several years on the Mk5 GTI. Your VW dealer's plug-in system should display your individual car's status.
« Reply #400 on: May 15, 2012, 03:29:43 pm »
If VW flash your ECU your map is gone completely not "buried".  :stupid:
For you to get the map back it will need to be flashed by the tuner or agent of the tuner depending on who's map you have. An SPS will be pointless.
Offline Mk5 GTian
  • -Receive: 37
« Reply #401 on: May 15, 2012, 03:32:22 pm »
Ian, do you know if they can replace the coil packs without flashing the ECU?  :confused:
« Reply #402 on: May 15, 2012, 04:37:57 pm »
....Okay, Ian (Hedge) but no need to smiley me as stupid! If the ECU flash destroys the remap then obviously the Revo SPS would be pointless.
Offline alackofspeed
  • -Receive: 24
« Reply #403 on: May 15, 2012, 11:43:14 pm »
My local dealer didn't touch the ecu map when they fitted my recall coils, instead the guy took about 1.5hrs to change 4 coils (and put a sticker on the boot floor)!  :stupid:
