Author Topic: Tyre Uneven Wear  (Read 3544 times)
Offline ub7rm
  • -Given: 35
  • -Receive: 43
Tyre Uneven Wear
« on: February 19, 2011, 10:18:21 am »
Had the MOT done today, passed but with a couple of advisory's.
First was a little bit of corrosion / pitting on the inside face of the front drivers side brake disc - fair enough I'll get new discs and pads as they've done 55k and probably towards the end of their life anyway.
Second one is a little more troubling, the 2 year old / 20k falken fk452's I've got on the back (with about 5mm tread left) are showing 'slight high / low spots on the inside edge'.  The exact same reason I prematurely binned the Dunlop Sportmaxx's that were on previously.  I had the alignment checked at the time and all was OK, read the many posts on the faults with the dunlops and put it down to that.  But obviously thats not the whole story.
Fair enough the tyres have done a fair bit of mileage and apparently the high/low spots are very slight but I'd be interested to hear others experience of this issue.  I thought it was pretty much confined to the Dunlops but clearly not.
Ah well, an excuse to put ps3 on the back as well as the front  :grin:
Sepang Blue S4 BE Avant
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: Tyre Uneven Wear
« Reply #1 on: February 19, 2011, 10:25:48 am »
I haven't experienced any trouble over 2 1/2 year with 17" goodyear ultragrips, 18" Bridgestone potenza re050a, 18" Toyo proxes R1R.
I would try the Michelin Pilot Super Sport over the PS3 if you are after 4 new tyres anyway  :drinking:
Over the top mod list ;o)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=q8bh4avsnfct8rlglbqral2rl1&/topic,19740.0.html
« Reply #2 on: February 19, 2011, 11:00:12 am »
Quite common this. I had 2 sets go 50p shapes on my old mk5. What year is yours? 05/06?
Offline Beddie
  • -Receive: 76
« Reply #3 on: February 19, 2011, 11:14:22 am »
Same thing happened to me with Falken FK452s on my old A3  :fighting:
Iirc Falken are part of Dunlop anyway and share carcass/tread technology, rumour has it that the FK452 is just a cheaper Dunlop Sportmaxx with a different tread pattern, both are best avoided imo...
Carbon Grey Edition 35 - Here
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #4 on: February 19, 2011, 12:12:46 pm »
It is indeed an 05 plate.
Interesting about the Falken / Dunlop connection.  That could very well explain it.
I had PS3's put on the front in December and have seen the light.  The PS3's are absolutely fine for my requirements and will stick to them rather than the super sports.
Thanks for the thoughts  :drinking:
« Reply #5 on: February 19, 2011, 12:17:57 pm »
05... intersting, as mine was also an 05 plate!
I had alignment done which didn't help. In the end I got the rear shocks replaced (180quid, so cheaper than chewing up tyres every 6 months), and that fixed it.  :happy2:
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #6 on: February 19, 2011, 12:29:35 pm »
Interesting - I had the alignment checked 2 years ago when I discovered the dunlops were almost worn through on the inside edge and apparently it was spot on.  Since its taken 2 years for the replacement tyres to show a very slight wear of the same type I am inclined to put it down to a poor choice of tyres just now.  MOT tester (dealer) didn't find anything wrong or have any possible explanation other than the type of tyre either.  Will keep an eye on it and will keep your finding in mind - could be the start of a problem.  :happy2:
« Reply #7 on: February 19, 2011, 12:35:47 pm »
I had premium brand Goodyear F1 GSDs on and even they got chewed up and 50p'd within a year (about 20k-25k miles).. so i dont think its tyre brand related. It was wheels in motion (chesham) who advised it might be the shocks.
It bugged the life out of me for a long time on my TDI.  :mad:
Offline Beddie
  • -Receive: 76
« Reply #8 on: February 19, 2011, 12:43:17 pm »
Goodyear are part of Dunlop too...  :wink:
Any directional tyres appear to a problem with the MK5 setup, Sportmaxx, FK452 and GSD3 are all directional, however i've had no problems whatsover with Assymetrical type tyres on any of the 3 MK5 chassis cars i've had  :happy2:
« Last Edit: February 19, 2011, 12:46:51 pm by Beddie »
« Reply #9 on: February 19, 2011, 12:50:20 pm »
Hmm maybe it was tyres then  :signLOL: ... because the last set of tyres i had on were Contis and they were fine!
« Reply #10 on: February 19, 2011, 02:34:09 pm »
I've now had 4 pairs of Goodyear asymmetrics and currently am on Dunlop Sportsmaxx asymmetrics all round. No problems with the Dunlops so far and one problem with driver's side front on GY asymmetric with excessive tyre wear on inside only. Bad! Down to canvas, rest of tread was 5mm. VWR thought it was down to tracking/alignment.
Car has been recently laser aligned and tracked on Hunter rig and only needed a small Toe adjustment since VWR set it up in 2009.
Offline Neimad
« Reply #11 on: February 19, 2011, 02:51:13 pm »
I've experienced this problem with every set of tyres I've had on the back axle so far, including the Dunlops it left the factory with and both Goodyear Eagle F1 GSD3's and Asymmetric's.  I've had alignment checked and even had the rear camber altered slightly in an effort to fix the problem but still no joy.  My car in an '06 plate and I'm genuinely considering binning the OE shocks and getting some Koni FSD's to replace them, especially since my car has now done over 100k so the original ones are probably showing their age.
Offline Russ_leeds
« Reply #12 on: February 19, 2011, 05:21:02 pm »
mines an 07 plate and when i bought it it had conti sport 2's on the back and they wore unevenly on the inside edge
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
RustyGTI
« Reply #13 on: February 20, 2011, 12:04:19 am »
Replaced the rears on my '07 GTi after 4 weeks of buying the car from a dealer...Bridgestone Potenza's were making an awful racket despite begin 'legal' - thought a wheel bearing had gone!! Replaced with Vredestien's - all quiet on the western front now...
Offline zoomered
« Reply #14 on: May 30, 2011, 04:22:34 pm »
Has anyone diagnosed the definate reason for this uneven wear?? I too have uneven on the rear and am thinking of replacing with Michelin PS3's or conti 3's..
What do you's think between the two?
