Author Topic: tyre rubbing after drop, advice needed.  (Read 2512 times)
Offline daboy3000
  • MKV GT TDi
« on: February 21, 2011, 01:09:41 pm »
Just had Eibach springs  put on, 20mm drop and am running OEM VW Chicago 18's and get a little rub if i'm turning at the same time as going over a dip, at some speed.
If it just happens every now and again could this cause a problem?
Soloutions?
« Last Edit: February 28, 2011, 11:05:56 am by daboy3000 »
Re: tyre rubbing
« Reply #1 on: February 21, 2011, 08:33:34 pm »
You should be fine, with the odd rub, cant see why they would rub though on a 20 mil drop  :chicken:  That should give bags of clearance. What is the wheel spec, width and offset.
Offline gazbutS3
Re: tyre rubbing
« Reply #2 on: February 21, 2011, 08:35:54 pm »
if its only a slight rub it'll be the liner at the screw attachment point at the top, remove screw tuck liner behind, sorted :happy2:
Offline daboy3000
  • MKV GT TDi
Re: tyre rubbing
« Reply #3 on: February 22, 2011, 09:21:19 am »
I believe they are 8" wide and ET44.  Tyres are 18-225-40
Found this site, maybe very handy for people who are looking at a change of wheel or need specs of OEM VAG wheels. It also talks about fitting a suspension limiting kit.
http://www.myturbodiesel.com/1000q/wheels/18-wheels-vw-5x112.htm
I will have a look at the liner too.
Offline daboy3000
  • MKV GT TDi
Re: tyre rubbing after drop, advice needed.
« Reply #4 on: February 28, 2011, 11:07:48 am »
I had a look at the weekend and saw the screw at the top of the liner.  Is it the best thing to remove this screw, is it easy to tuck the liner in higher.  Has anyone else had this issue?
« Reply #5 on: February 28, 2011, 11:20:22 am »
Most members on here who have lowered thier golfs have done this littlt mod..take you 10 min to do
Offline daboy3000
  • MKV GT TDi
« Reply #6 on: February 28, 2011, 11:22:30 am »
Do I need to take the wheels off?
« Reply #7 on: February 28, 2011, 11:39:03 am »
....I now wish I'd done that rather than tuck the arch itself and crack off the paint so that I now need carbon wings!  :stupid:
« Reply #8 on: February 28, 2011, 12:40:55 pm »
out of interest how much are carbon wings
Offline big al
« Reply #9 on: February 28, 2011, 12:52:43 pm »
Now that sounds like a post where you are convincing yourself Robin,  :signLOL:
I too bent the screw housings and that in turn has cracked the paintwork around the arch.
Though I won't be spending £1000 on carbon wings  :wink:
Local garage has quoted me £200 to sort both wings out.
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #10 on: February 28, 2011, 01:38:01 pm »
Do not use limiters, these are crap !!
What about the screw in the wheel arch?
Is it removed yet?
"You get what you pay for."
« Reply #11 on: February 28, 2011, 02:14:54 pm »
....If you've only been quoted £200 I'd check exactly what would be done. Both myself and another guy on here have been quoted just under £400 (inc vat) and the materials alone are over £100. Job would take 3-4 days too to allow proper drying/curing between processes.
