Author Topic: Revision D diverter valve  (Read 3692 times)
Offline craig_t
  • Craig
« on: February 24, 2011, 06:13:34 pm »
3 months after having a remap my early DV has died, replacing it this weekend with a revision D one.
Does the revision D give off any "dump" noise when lifting off the gas as my original one did???
« Last Edit: February 24, 2011, 06:15:12 pm by craig_t »
Admin notice, sig pic removed for being to big.
Offline bodger00
  • -Receive: 20
  • A wish called Zonda
Re: Revision D diverter valve
« Reply #1 on: February 24, 2011, 06:20:16 pm »
Slightly different noise but it does yes.  :smiley:
Offline craig_t
  • Craig
« Reply #2 on: February 24, 2011, 09:08:22 pm »
Cheers for the reply.
I'm pretty sure my DV is dead. After 3k revs the dv sounds like it's wide open and is dumping all my boost :(
Got to be the diverted valve hasn't it ????
Offline bodger00
  • -Receive: 20
« Reply #3 on: February 24, 2011, 09:20:33 pm »
It's sounds like it. If you are hearing a long whoosh blowing noise then it probably has a hole in the diaphragm.
Offline craig_t
  • Craig
« Reply #4 on: February 24, 2011, 09:21:48 pm »
Yeah defo hearing the long whoooosing. And the car feels so flat!!!
Offline craig_t
  • Craig
« Reply #5 on: February 26, 2011, 05:47:10 pm »
Fitted the new diverted valve this afternoon. Pretty straight forward job, just a bit awkward getting to the top bolt. Once removed there was 2 tears in it. One was pretty big and there was another small tear next to it.
Defo recomend getting a "revision D" to anyone, with it fitted car feels very strong when in boost. Makes me wonder how long iv had a hole in as I guess they all start pretty small and gradually get bigger.
Anyway all in all, a simple job  :happy2:
Offline Creatz
  • The Noob
« Reply #6 on: February 26, 2011, 06:48:40 pm »
how much did the rev D set you back ?
Offline alexperkins
  • -Receive: 99
« Reply #7 on: February 26, 2011, 07:24:23 pm »
Id like to know that too
Offline Thor
  • -Receive: 25
« Reply #8 on: February 26, 2011, 07:29:29 pm »
Got mine from JKM, £45+ vat.  get one ordered.  :happy2:
http://www.jkm.org.uk/performance/divertervalves.htm
« Last Edit: February 26, 2011, 11:06:16 pm by Thor »
                                     Mk6 GTI
Offline Creatz
  • The Noob
« Reply #9 on: February 26, 2011, 08:45:39 pm »
Cheers Thor.
I was reading some bhp runs from the JKM RR day and some of the lower readings
were all down to a Blown Diverter valve.
Is there anyway to check if its blown or is it just a case of knowing the car runs like poo
excuse my dumbness lots of reading and fiddling with the car as i go along will help me out.
Offline craig_t
  • Craig
« Reply #10 on: February 26, 2011, 10:49:31 pm »
The diverter valve set me back £49 inc VAT from VW/Audi parts store.
Ul know if it's gone cause the car just won't pick up. You will also hear a whoosing noise as you accelerate. That will be the boost escaping threw the tear.
Offline Thor
  • -Receive: 25
« Reply #11 on: February 26, 2011, 10:58:58 pm »
On the GTI you need to get under the car as the DV is near the turbo, on the Edition 30 it is visible when you open the bonnet, lower right of engine cover near to air intake.  The 13th post (warren cox) on the thread below has a picture guide on how to check them.  :happy2:
http://www.mk5golfgti.co.uk/forum/index.php/topic,7793.0.html
                                     Mk6 GTI
« Reply #12 on: February 26, 2011, 11:16:50 pm »
If you have access to VCDS you can log boost and N75 activity.
They will show evidence of a boost leak and if that's the case then the DV is an easy fix/check.
