Author Topic: Torque setting - Brake caliper carrier bolts??  (Read 14439 times)
Offline bodger00
  • -Receive: 20
  • A wish called Zonda
« on: February 24, 2011, 07:37:36 pm »
I have had a quick look in the workshop manuals on here and think I have found them as 190Nm but its not clear. The 2 bolts are 21mm and its the front wheel caliper carrier.
Is this the right torque setting? As that's f***ing tight!
« Last Edit: February 24, 2011, 07:43:09 pm by bodger00 »
Offline bodger00
  • -Receive: 20
Re: Torque setting - Brake caliper carrier bolts??
« Reply #1 on: February 24, 2011, 09:40:44 pm »
Bet Mr Brakes daveb knows
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
« Reply #2 on: February 24, 2011, 09:57:25 pm »
Its M14 Metric fine so M14x1.5x35, from memory its a 10.9 so you're good up to 220nm beleive it or not, so 190 with a collared bolt doesnt sound unreasonable.
Its only 140lbs ft if that sounds more like it!!
If you've got a bit of time then renew the bolts, they 10.9 class so not stretch bolts in the true sense but you dont want to be swinging off them more than twice.
I think they're N90948802 prob cost you a fiver for all four
Offline QD MBE
  • -Receive: 102
« Reply #3 on: February 24, 2011, 10:05:31 pm »
190nm is 100% the correct value. :happy2:
Offline bodger00
  • -Receive: 20
« Reply #4 on: February 24, 2011, 10:07:17 pm »
Cheers Dave I knew you would know. I have just reassembled so no chance to renew but I did have to swing off them to undo them :happy2:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=ht9njpv57ac06jjfuq645hc401&/topic,19740.0.html
« Reply #5 on: February 24, 2011, 10:29:54 pm »
It's a lot of torque, but it's the carrier that takes the load from the pads! I renewed the bolts too, better safe that sorry.
