Author Topic: retro fit tyre pressure kit  (Read 6818 times)
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« on: February 26, 2011, 12:06:14 pm »
i have just brought the tyre pressure kit off another member (switch + loom) has/does anyone know how easy if is to fit?? would it need coding to my car??
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: retro fit tyre pressure kit
« Reply #1 on: February 26, 2011, 02:23:33 pm »
easy to fit
Cluster and Key coding
Location Great Yarmouth
Offline DamoP
  • -Receive: 115
« Reply #2 on: February 26, 2011, 04:33:41 pm »
Is there a fitting thread that you know of?? and will it need coding??
Offline Snoopy
  • -Given: 31
« Reply #3 on: February 26, 2011, 06:04:55 pm »
If we are talking VWs TPMS
This Maybe of some help
http://www.mk5golfgti.co.uk/forum/index.php?topic=7677.0
and
Here's a bit more detail.
Basically it can be installed without cutting any wires you only need to run one wire from the swtich up to the ABS controller behind the battery.
The other connections can all be taken from the ESP swtich and using a combo of pre-made wires and a couple of connector housing it will look something like this: -
Wires taken out of the ESP switch into another connector housing
New loom reconnected to ESP swtich to "pick-up" the required power/signal's
All complete and looking OEM (other than I only had black cable ties and OEM fit is clear)
  :smiley:
« Last Edit: February 26, 2011, 06:06:40 pm by Snoopy »
Offline DamoP
  • -Receive: 115
« Reply #4 on: February 26, 2011, 06:19:20 pm »
Thanks mate ,  ill tackle that next week. where did you go through the bulk head?? is it obvious where the connection goes on the abs controller??
i see you have 4 switches on yours , what are the other 2??
Offline Snoopy
  • -Given: 31
« Reply #5 on: February 26, 2011, 09:04:53 pm »
Not my photos there SteveP's of his mk6 but its more or less the same.
His has lots of options.
It had the adjustable suspension, Parking sensors, ESP switch.
The coding via VCDS is very simple and just tick boxes.
« Last Edit: February 26, 2011, 09:11:36 pm by Snoopy »
Offline parks
  • Red ED30 No. 1778 Detailing World member
« Reply #6 on: February 26, 2011, 10:20:26 pm »
Slightly off topic, but what could you use the other blanks for? On a mk5 without the fancy suspension.
Standard: Rear parking sensors, Parrot Bluetooth
Retro fitted: MFSW buttons, RCD510, Boot pop, Black Monza II, Xenons, Audi jacking points, open fog light grills.
Offline StephenED30
  • -Receive: 53
  • Edition 40 No 135
« Reply #7 on: February 27, 2011, 01:57:23 pm »
Offline DamoP
  • -Receive: 115
« Reply #8 on: March 02, 2011, 04:45:14 pm »
cheers for all your help guys , was easy enough to do.... apart from getting the wiring through the bulk head
Offline whiteatom
« Reply #9 on: March 10, 2011, 10:33:36 pm »
Hi
Can anyone point me in the right direction for some instructions to fit this kit ? I have the loom + switch but no english instructions.
Many thanks in advance
Offline DamoP
  • -Receive: 115
« Reply #10 on: March 10, 2011, 10:40:09 pm »
Hi
What do you need to know?? all the info i used if off this thread
Offline whiteatom
« Reply #11 on: March 10, 2011, 10:47:17 pm »
The kit I got has a black plastic plug connector and then 3 grey wires (not connected in ) with no instructions on what order they go in ! I was expecting a plug and play loom for the switches then connect the 1 wire to ABS unit + re - code.
Any info ?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #12 on: March 11, 2011, 06:33:18 am »
You need to remove 3 wires from the ESP plug, then you insert them into the plug supplied. The 3 wires on the loom go to the ESP plug
ESP Plug
GREY Wire (pin 3) - Remove and fit to pin 1
BROWN Wire (pin 6) - Remove and fit to Pin 3
BLACK AND BLUE or BLACK AND GREEN (pin 4) - Remove and fit to pin 2
Offline whiteatom
« Reply #13 on: April 25, 2011, 01:23:27 pm »
Just in process of fitting , can anyone confirm which pin the wire to ABS controller needs to be in ? On the loom wire it says pin 07 , but in Germany instructions says Pin 27 / Pin 41 ?
Many thanks
I have a mk5 Gt tdi 4 motion on 05 plate if this makes any difference ?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #14 on: April 25, 2011, 01:56:03 pm »
PIN 27
unless you have DSG
