Author Topic: RNS 510 Comes tomorrow Aerial Question ?  (Read 11904 times)
Offline parks
  • Red ED30 No. 1778 Detailing World member
Re: RNS 510 Comes tomorrow Aerial Question ?
« Reply #45 on: March 02, 2011, 01:21:20 pm »
Not the one above  :confused: the one Ive got has a double connection the the back of the head unit and a single which connects onto one of the existing wires.  Plus its alot thicker.
You have the wrong one then
so i can get rid of this one, then unclip the existing wires, or one at least then attached them directly with tape...
Standard: Rear parking sensors, Parrot Bluetooth
Retro fitted: MFSW buttons, RCD510, Boot pop, Black Monza II, Xenons, Audi jacking points, open fog light grills.
Offline 182_blue
  • -Receive: 54
« Reply #46 on: March 02, 2011, 06:39:49 pm »
Yes do as i put further down in the post , my edition 30 worked fine for 2 years like that :-) other than that its buying the proper cable
Offline Creatz
  • The Noob
« Reply #47 on: March 03, 2011, 03:49:35 pm »
the cable i bought worked perfect just clipped together,my only worry is
if i put my ear to the unit,it sounds like the hard drive is still working ?
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #48 on: March 03, 2011, 04:10:16 pm »
The unit shuts down on a time delay, so wont fully power down until x minutes after the ignition is turned off you can also hear the cooling fan after a long run.  This is the reason why certain cars get battery drain as the unit doesnt fully switch off as the communication with the can gateway doesnt work correctly.  Since you had the newer version gateway you shouldnt have an issue.
You will know if the unit has fully shut down as you will get the splash screen (VW logo) the next time you boot it up if you havent been away for too long the unit will instantly fire back into life, something like putting a laptop into sleep mode.  :happy2:
Offline Creatz
  • The Noob
« Reply #49 on: March 03, 2011, 04:54:35 pm »
Ok so if I don't get the vw logo tomorrow or how many hours later ?
Then I know there's a prob
Offline Creatz
  • The Noob
« Reply #50 on: March 03, 2011, 05:31:39 pm »
Just to add i fitted this myself and managed to get 9/10 satellites after carefully placing the antenna under the dash.
So glad i didnt pay anyone to fit it  :happy2:
Offline SeanyK
  • -Given: 35
« Reply #51 on: March 03, 2011, 05:48:27 pm »
Rightly so mate, enjoy it, I can't believe how good it is, it started telling me about traffic problems on my journey, yet I wasn't even using the sat-nav as such, I was just driving home from work, and lo and behold, a traffic jam just after my turn off!
Top top radio, I'd recommend it to ANYONE, skip the RCD and go straight for the RNS!
Offline Creatz
  • The Noob
« Reply #52 on: March 03, 2011, 06:26:34 pm »
also something tomtom make you pay a yearly fee for
Offline Creatz
  • The Noob
« Reply #53 on: March 04, 2011, 12:20:05 am »
No VW Logo when i turned it back on after sitting for 5hrs,just came back on like a laptop coming out of sleep.
I'm now worried its not shutting down properly,could it be a setting in VAGcom that needs changing on
the can bus ? if so can someone tell me what it is so i can run it up to my friend.
Offline alexperkins
  • -Receive: 99
« Reply #54 on: March 23, 2011, 11:12:55 pm »
Did it start shutting down properly or did you get a new gateway/change software?
Offline Creatz
  • The Noob
« Reply #55 on: March 23, 2011, 11:55:01 pm »
Nah it was fine, due to a warranty can bus replacement just before I owned it, I didn't need to
Change it thank god  :jumping:
I kept leaving the unit on radio when I switched the car off and
You won't get a splash screen from leaving it on radio as that can come on instantly and doesnt
Require the use of the HDD.
Plus if you unlock the car and open the passenger door on a quiet road,lean over open the drivers door from inside you will
Hear the unit begin to boot up if it's working properly
I should of updated this post really  :signLOL:
« Last Edit: March 23, 2011, 11:58:21 pm by Creatz »
Offline alexperkins
  • -Receive: 99
« Reply #56 on: March 24, 2011, 07:11:36 am »
Ah yes I remember you saying! Oh well my new can gateway turns up today so itll be problem solved  :signLOL:
Offline Creatz
  • The Noob
« Reply #57 on: March 24, 2011, 09:26:36 am »
if your can gateway is located like mine,behind the little cupboard.
its easier to change if you go from the top under the bonnet,
there is a removable plate just underneath the wiper blade motor mate  :happy2:
Offline alexperkins
  • -Receive: 99
« Reply #58 on: March 24, 2011, 09:36:49 am »
I may have to get you to show me later :P What year is yours?
Offline Creatz
  • The Noob
« Reply #59 on: March 24, 2011, 09:59:51 am »
Dec 2007  (57 plate)
