Author Topic: stage 1 mod, does fuel consumption go up?  (Read 4477 times)
Offline Homer
« on: February 28, 2011, 09:48:52 pm »
Hi all, if I get this mod will fuel consumption go up? Thanks
Offline Janner_Sy
  • -Receive: 113
Re: stage 1 mod, does fuel consumption go up?
« Reply #1 on: February 28, 2011, 09:52:07 pm »
at first yes, purely as you start driving like a loon due to the smile you get when you boot it.  However driven sensibly my mpg improved by 2-3mpg
Offline Bernhard30
« Reply #2 on: February 28, 2011, 11:41:18 pm »
Yes I think you'll find after a Stage 1 map, you will burn some more juice, purely given the addictive thrust of a Stg1 car.
Goodness only knows how many times I've had to take the long way home recently. Car was mapped in December.
My Ed30 with Autotech high flow fuel pump, Dbilas Induction kit and Milltek downpipe/catalyst with a stage 1 Revo map is just fab. Good fun too..
« Reply #3 on: March 01, 2011, 12:43:25 am »
Surely you're not thinking of getting this mod to improve your mpg  :confused:
Good luck with that! It ain't gonna significantly happen.
Offline Poppa Dom
« Reply #4 on: March 01, 2011, 08:24:29 am »
How long is a piece of string? It all depends how you drive it. If you are being frugal then it will return a 2-3 mpg gain over standard, start booting it around all over the place and you will see lower fuel economy than standard.
Offline winrya
« Reply #5 on: March 01, 2011, 08:34:08 am »
I'm not sure I noticed any change at all
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #6 on: March 01, 2011, 08:39:35 am »
Well my pieces of string measure 53cm , 60cm and 108cm.  :grin:
My Bluefin allows me to use lower gears/rpm in and around town which helps my mpg around town a bit  ,elsewhere there is no change
« Reply #7 on: March 01, 2011, 08:43:56 am »
.... x 2
Which probably means that we've got the balance right between cool cruisin' and enjoying ourselves on spirited driving. :happy2:
Offline Janner_Sy
  • -Receive: 113
« Reply #8 on: March 01, 2011, 08:45:14 am »
.... x 2
mine was definitely thirsty @ stage 2+ though.  struggled to get 30mpg on a good day lol
« Reply #9 on: March 01, 2011, 08:46:34 am »
....Be careful not to let your piece of blue string lull you into lazy habits and use the torque too much. Torque kills.
« Reply #10 on: March 01, 2011, 08:49:59 am »
.... x 2
...."on a good day" is the giveaway  :grin: - Seeing anything over 30 mpg makes me wonder if I'm having a good day. I think that 33 mpg is the most I have ever seen.
Offline Boothy
« Reply #11 on: March 01, 2011, 10:23:33 am »
Had my stage 1 for around 18 months now and in all honesty if you drive normally then the cold weather makes more of an impact on mpg than the remap. Of course the difficulty comes in driving it 'normally' with the added power.
 On my 25 mile commute with a mixture of up, down and flat roads I usually get around 30 mpg. If I try though I can it up to 37 on the same journey but I can never be arsed.  :laugh:
Offline martziniuk
« Reply #12 on: March 01, 2011, 07:20:46 pm »
Standard to stage 1 mpg stayed the same for me, stage 3 gives superb motorway mpg @ 38mpg but around A and B roads fairly sensibly driven gives around 31mpg.
Offline theo
« Reply #13 on: March 01, 2011, 11:32:35 pm »
I got 38mpg once out of my 2+ ED30 and almost died of boredom. My usual is around 28 :happy2:
« Reply #14 on: March 02, 2011, 11:11:33 am »
....I'm the same. It's the difference between enjoying driving and it almost being a chore  :happy2:. No wonder so many motorists don't enjoy their journeys just sat there in their caccoon negatively thinking about their mpg.
