Does anyone have a control column wiper stalk diagram?
Or maybe even an up-to-date fuse box diagram for 2005-2006 cars?
Why? Read on......
A slightly bizarre fault:
Did MOT a week ago, tester said failed on front washers not working then when he went to fix he found they were working working......
Mmmm.
Fast forward a few days, the front wash/wipe now stopped working. Wipers fine on wipe only, rear fine.
Checked fuses.
F36 fuse (20 Amp) in fascia fuse box blown.
Changed fuse, still not work.
Mmmm, try ignition leaving 5 minutes - works!
A day later, stops working again.
No fault codes on my OBDII [added after comment below]
Check fuses (I hate not having a reliable fuse map
) and can't find any blown.
Plenty of water and when I stimulate directly with 12 volts the pumps work and the outlets spew water.
The relay is fine.
Tried the bonnet switch, no joy (but as wipers work except for wash/wipe I wasn't expecting this to be faulty) [added after comment below]
This leaves just about the only remaining candidate as the control column stalk........but I don't have a circuit diagram to check the outputs before I start having a go at cleaning all the connections.
I tried the Russian servicing manuals listed elsewhere on the site and can't find anything there.
Cheers,
Ian
