Author Topic: SPS Switch and engine warning light?  (Read 4237 times)
Offline RagingKileak
« on: March 03, 2011, 09:21:25 pm »
Hi guys,
Just wondered if I can use my SPS Plus switch to read and possibly reset error codes? Specifically I have an engine warning light, but no apparent running problems.  Any ideas?
Car is stage 2+ and running some slight tweak VIA the SPS. I've now switched to the stock 'performance' map as thought perhaps it is fuel/cat related? Car does smell a little 'petroley'
Matt
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: SPS Switch and engine warning light?
« Reply #1 on: March 03, 2011, 09:25:18 pm »
I don't think so Matt, it's certainly not a documented feature.
Stu...
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #2 on: March 03, 2011, 09:27:44 pm »
Are you running an aftermarket fuel pump?
Stu...
« Reply #3 on: March 03, 2011, 09:48:07 pm »
I am mate, yes.
Matt
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #4 on: March 03, 2011, 09:56:17 pm »
I'd check your engine oil for excess fuel.
Stu...
« Reply #5 on: March 03, 2011, 10:07:53 pm »
Also Matt see if anyone is close by to you with a VCDS cable, most are happy to help out fellow members for a thankyou.  http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html
« Reply #6 on: March 03, 2011, 10:17:01 pm »
Bums. That sounds bad right? Might just bounce right on down to Stattlers!!
Matt
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #7 on: March 03, 2011, 10:19:30 pm »
Well I wouldn't suggest a mad panic just yet but as you say you can smell fuel in the car and you have a CEL then it may be low rail pressure and a failed seal in the fuel pump.  Is it internals or APR?
Simple check is to rub the oil from the dipstick in your fingertips, smell it for fuel and feel it's viscosity.
Stu...
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #8 on: March 03, 2011, 10:24:06 pm »
You definately can't read or reset error codes with an SPS+
I'd follow Stu's advice and get someone nearby with VCDS to check.
I see you mention Stattlers i know Hurdy uses them and he has VCDS
« Reply #9 on: March 03, 2011, 11:18:55 pm »
I own Hurdys old car mate :)
Pretty sure its internals - supplied by Stattlers so makes sense going there.
Can only smell fuel outside the car, not in. Obviously needs checking anyway!!
Thanks chaps.
Matt
Offline TrickGTI
« Reply #10 on: March 04, 2011, 06:33:16 pm »
What exhaust are you running sports cat de cat or standard?? I have a de-cat and it stinks really fumey, makes a massive difference over having the cat in the system.
2006 Tornado red GTI
« Reply #11 on: March 04, 2011, 11:13:22 pm »
Milltek sports cat mate. Now limp moding when I hammer her!!
Matt
« Reply #12 on: March 13, 2011, 06:23:03 pm »
Sparkplugs.
So much better now and made a massive torque figure of 365 lbs/ft.
Matt
« Reply #13 on: March 13, 2011, 10:21:41 pm »
Top Cat told me you were having problems today Matt. Don't usually look in this section now I have a Jap car :ashamed:
I was a little worried, but glad it looks like Eddie is still going well :happy2:
« Reply #14 on: March 13, 2011, 11:37:37 pm »
It's ok mate, dont worry. She gets the proper care and attention that's required!!
Feels much better so I guess the plugs have been on their way since not long after you sold her to me. You remember when we chatted about how I was losing out to supposedly slower cars?
Amazing difference now... smooth and silky. Made 355 bhp on Steve's dyno along with the 365 lbs/ft. I was happy to see it pull that I can tell you.
Unfortunately, now slightly wining under deceleration, but I'll get that looked at shortly along with suspension Mods!!
Hope you're well mate.
Matt
