Author Topic: RNS 510 Latest VW Firmware and Maps  (Read 4258 times)
Offline Creatz
  • The Noob
« on: March 03, 2011, 11:15:54 pm »
Does anyone here who goes to Red Robins end of the month meets have the latest VW Firmware and Map Update?
The top of my unit says.
HW 04
SW 2680
My unit hasn't had any updates but has had the VIM lock disabled,if i update it, will it put the lock back on ?
and is it worth doing? or is the version I'm on worth leaving as it is?
i dont want to put any beta or none VW firmware on it
Thanks Creatz
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: RNS 510 Latest VW Firmware and Maps
« Reply #1 on: March 03, 2011, 11:25:32 pm »
See here for the latest firmware
http://www.mk5golfgti.co.uk/forum/index.php/topic,23779.0.html
I'm not 100% certain but pretty sure it will remove the VIM Lock.
You need to check the hidden menu to see if it is still running that firmware. Press and hold setup for 30 secs and you should get to the hidden menu if it's enabled.
Offline Creatz
  • The Noob
« Reply #2 on: March 03, 2011, 11:31:31 pm »
will go outside and check that now
Offline Creatz
  • The Noob
« Reply #3 on: March 03, 2011, 11:43:11 pm »
nope.It just went to an FM / AM service Mode.
Whats more worrying is that when i turned it on it went straight to Radio and i didn't get the
VW boot up logo,which is telling the unit isn't shutting down properly  :scared:
but when i clicked on the Media button it did say "starting up"
im confused now ???
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
« Reply #4 on: March 03, 2011, 11:44:59 pm »
The Radio starts pretty much straight away.
If you put the firmware on that i linked above you will have the hidden menu enabled. :happy2:
Offline Creatz
  • The Noob
« Reply #5 on: March 03, 2011, 11:50:00 pm »
I'm more worried about the VIM lock going on  :signLOL:
My little ones like to watch Simpsons while we drive up north.
someone told me that if i don't get the VW logo on first switch on
then the unit isn't shutting down properly and is still running ?
