Author Topic: Front cigarette lighter socket not working  (Read 54023 times)
Offline golftdi04
« on: March 06, 2011, 08:24:13 pm »
Hi
the front fag lighter socket (needed urgently for satnav) in my 04 golf se tdi (1.9) doesn't work. (sorry, know it's not a GTi but wondered if you chaps could help!)
The rear one does and I've checked and replaced fuses 24 & 26 (in the dash/drivers fuse box) as indicated in the fuse plan.
The front socket still isn't working - anyone have any ideas?
Thanks a lot
 :drinking:
Offline alexperkins
  • -Receive: 99
Re: Front cigarette lighter socket not working
« Reply #1 on: March 06, 2011, 08:26:18 pm »
You are testing with the ignition on i presume?
Check fuse 28 (20A) as this is the pre 05 12v socket fuse  :happy2:
Offline golftdi04
« Reply #2 on: March 06, 2011, 08:38:46 pm »
by ignition on do you mean engine actually turned on or key just turned (So lights and radio etc. come on).
there's a 25amp fuse in 28 and it tested okay (the leaflet in the fusebox lid has this slot as a blank)
Offline alexperkins
  • -Receive: 99
« Reply #3 on: March 06, 2011, 08:41:01 pm »
Just key on mate
Interesting...id try a fresh fuse just in case. Fuses can be funny things sometimes
Offline Creatz
  • The Noob
« Reply #4 on: March 06, 2011, 08:42:42 pm »
check the hand book to find out exactly which fuse it is.
if its fine then lift the centre out and check the cable as some people have been known to wire hands free kits to it
« Last Edit: March 07, 2011, 12:30:19 am by Creatz »
Offline golftdi04
« Reply #5 on: March 06, 2011, 08:47:23 pm »
I don't have a handbook unfortunately as I've just bought the car and they serviced it when I bought it so they're stamping it up and sending it on with receipts for the cambelt kit and waterpump change they've said they've done.
All I have is the little leaflet in the lid of the fuse box which indicated number 24 as the cig lighter and 26 as the charger socket.
I've tested (they were okay) and replaced both those fuses.  But a 25a in each IIRC
How do you remove the centre?
Offline Creatz
  • The Noob
« Reply #6 on: March 06, 2011, 08:51:45 pm »
The gear stick gator pops up and there are 4 t20 torque screws under there.
the cigarette tray should just pop out.
Check underneath and if the wires are disconnected the chances are they
may have been used for something else
Offline golftdi04
« Reply #7 on: March 06, 2011, 08:53:29 pm »
Will go do that now - cheers mate
Offline Creatz
  • The Noob
« Reply #8 on: March 06, 2011, 08:55:48 pm »
http://www.golfmkv.com/forums/showthread.php?t=94994
there are some pics on how to remove it there
Offline golftdi04
« Reply #9 on: March 06, 2011, 09:21:57 pm »
top man, got it off and on the underside of the socket there's a 3pin plug connected to it (and a little green thing clipped to the side) does this sound normal?
Offline golftdi04
« Reply #10 on: March 06, 2011, 09:28:05 pm »
looks identical to this (but it's connected and the black thing piggybacking off the bottom of the socket, is green on mine...doubt it makes any odds.)
« Last Edit: March 06, 2011, 10:03:20 pm by golftdi04 »
Offline golftdi04
« Reply #11 on: March 06, 2011, 10:52:28 pm »
Also, is my "ABS/ESP" Fuse supposed to be empty??
Offline Creatz
  • The Noob
« Reply #12 on: March 07, 2011, 12:28:49 am »
no
when you hold the ESP button down does it show on the dash in yellow as off ?
sounds like you may have a few issues with it mate, if you bought from a dealer
i would make them fix it under the warranty
Offline golftdi04
« Reply #13 on: March 07, 2011, 01:32:10 pm »
no
The dealers a good 30 miles away and I use the car 6 days s week for work so trying to avoid that Tbh
The esp button goes amber when pressed - i'll check to see whether the dash does too
Offline alexperkins
  • -Receive: 99
« Reply #14 on: March 07, 2011, 01:35:41 pm »
Thats the older ESP system where the button illuminates instead of the dash
