Author Topic: Footrest Removal Problem  (Read 2501 times)
Offline Kalpsn2000
  • -Receive: 56
« on: March 08, 2011, 02:39:01 pm »
Ok, so at the weekend I tried to remove the footrest to fit an aluminum plate following this guide:
http://www.rforum.co.uk/index.php?;topic=419.0
Sounds easy I thought.
But after spending ages trying to get the Torx T15 screw out (cutting my finger in the process) I gave up :sad1:
It just keeps turning but won't come out, so I can't remove the footrest.
Any ideas?
Re: Footrest Removal Problem
« Reply #2 on: March 08, 2011, 03:53:13 pm »
i did a guide too: http://www.mk5golfgti.co.uk/forum/index.php/topic,2972.240.html
if it just keeps turning you need to get something in behind it and gentle apply pressure outwards (towards you) which will force the plastic screw to 'bite'  :happy2:
Offline Kalpsn2000
  • -Receive: 56
« Reply #3 on: March 08, 2011, 04:20:20 pm »
Would somthing like a credit card do the job? Is there space to get that behind there?
« Reply #4 on: March 08, 2011, 04:45:42 pm »
a credit card might do the job, could be a tad flimsy though but youre getting the idea, even a thin screwdriver to act as a lever would do it - its more about pressure on getting the plastic toward you so the screw will 'bite'
Offline Kalpsn2000
  • -Receive: 56
« Reply #5 on: March 08, 2011, 04:56:28 pm »
Ok thanks VC.
Will give it another go at the weekend if I get the chance.
