Author Topic: Boot rattle?  (Read 7717 times)
matt a
Boot rattle?
« on: February 27, 2009, 01:08:41 pm »
Does anyone else have a really annoying rattle coming from the boot area?
Any ideas? Doing my nut in.
Offline gazbutS3
Re: Boot rattle?
« Reply #1 on: February 27, 2009, 02:39:39 pm »
is the rear seat latched properly, mine used to rattle like a bugger, I ended up putting some tape round the loops that latch and it cured it :happy2:
Offline bennylenny88
  • needs moar lowwww
Re: Boot rattle?
« Reply #2 on: February 27, 2009, 03:21:23 pm »
check your spare tyre too :)
Offline nobby
Re: Boot rattle?
« Reply #3 on: February 27, 2009, 03:59:47 pm »
Yes i have exactly the same problem, will check out the solutions.
matt a
Re: Boot rattle?
« Reply #4 on: March 02, 2009, 07:44:48 pm »
Thanks Gaz, Ill look into that.
Benny don't think its the spare.
Offline vwrascal
Re: Boot rattle?
« Reply #5 on: March 02, 2009, 07:57:18 pm »
I have a rattle from boot area too  :confused:  sounds like its coming from the passenger side   :sad:
matt a
Re: Boot rattle?
« Reply #6 on: March 02, 2009, 09:51:42 pm »
Sounds like there's a canary in the boot.
Offline kris
Re: Boot rattle?
« Reply #7 on: March 05, 2009, 12:53:49 pm »
Yea I've got it too! Wondered if it was the parcel shelf somehow, because mine never used to squeek until the car was valeted and the parcel shelf was taken out and put back in... hmmmm
Offline ub7rm
  • -Given: 35
  • -Receive: 43
Re: Boot rattle?
« Reply #8 on: March 05, 2009, 01:09:36 pm »
I have this irritating noise from the boot.. whenever I go over speedhumps or the like I can hear this thump....thump.  Pretty sure its something swinging about like a cable behind a bit of trim.  Behind the trim of the bootlid most likely but I can't be asred investigating.  Anyone looked in this area before?
Sepang Blue S4 BE Avant
Offline cal tdi
  • dub or die
Re: Boot rattle?
« Reply #9 on: March 05, 2009, 01:19:08 pm »
its not the rubber balls on the bottom of the parcel shelf hangers is it? if these arnt attached they will be swinging about *image of two balls swinging*  :scared: :signLOL:
Candy weiß Mk6 GTI - Stage 2
matt a
Re: Boot rattle?
« Reply #10 on: March 05, 2009, 02:46:36 pm »
Mine sounds like a little bird chirping away over any bumps. Definitely sounds like it is coming from the centre of the boot area, I wondered if it was the boot mechanism?
Re: Boot rattle?
« Reply #11 on: March 05, 2009, 09:03:59 pm »
OMG!  :grin:
i've been trying to solve this for ages....that's so it on mine , so obvious  now you say it :grin:
Offline ub7rm
  • -Given: 35
  • -Receive: 43
Re: Boot rattle?
« Reply #12 on: March 06, 2009, 08:08:51 am »
Had a quick look at this this morning and I'm sure thats what it is.  Cheers fella.  Whats the best way of sorting this? Tape them up into position?
Damn VW and their cost cutting.  In the Mk4 the cord was retracted into a little spool.  Ah well.
matt a
Re: Boot rattle?
« Reply #13 on: March 07, 2009, 08:08:34 am »
I'm making some videos
Offline QD MBE
  • -Receive: 102
Re: Boot rattle?
« Reply #14 on: March 07, 2009, 09:27:55 am »
Matt,
Take a look at the Boot Lid Rubber Stops.  On the actual hatch they are adjustable.  You have to loosen an allen key (3mm) and then pull the stop on a ratchet stepped retainer (you will know when you see it)
One pointer would be - Is you hatch easy to close?  Mine is not too hard, but not too easy, it sits on the rubbers nicely, but over time they settle.
