Author Topic: 3D rear badge  (Read 1301 times)
Offline liver
3D rear badge
« on: March 08, 2011, 04:35:26 pm »
i have lost or had stolen the silver of the 3d badge, i still have all the mechanism etc but missing the vw part
does anyone know where i could find one?
Also do you think this is the 3D badge? http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=130438946818&ssPageName=STRK:MEWAX:IT
if it is i will just order one of these it seems look like it is
cheers
Offline Jaywoo-GTI
  • -Given: 38
Re: 3D rear badge
« Reply #1 on: March 09, 2011, 09:18:20 am »
Don't believe you can buy the 3d part separate from VW but i am aware that if you separate a mk4 golf rear badge from it backing it will fit a mk5, Not perfect but don't think anyone would ever notice.
P.S. that link is just a mk4 black badge marketed as a mk5 badge to rip people off, I know this as i fell for it.
Offline liver
Re: 3D rear badge
« Reply #2 on: March 09, 2011, 11:00:29 am »
cheers did this one not fit then as this would be the same as the peeled off mk4 badge no?
is there much difference between the two?
Offline Jaywoo-GTI
  • -Given: 38
Re: 3D rear badge
« Reply #3 on: March 09, 2011, 11:07:09 am »
Is does fit but advertised as a fit to a MK5 which it is not, need to cut all the tabs off the back of the badge and remove the plastic part behind, Then will need glueing/bonding on the handle.
Only major difference when it attached is it leaves a bit of a gap round the outside of the badge but cant be seen once the handle is in the closed position.
Black Badge is only about £15 from VW.
« Last Edit: March 09, 2011, 11:12:22 am by Jaywoo-GTI »
Offline liver
Re: 3D rear badge
« Reply #4 on: March 09, 2011, 11:18:28 am »
is that the mk4 black badge? do you have any of the picks from when u had the mk4 one fitted?
Offline Jaywoo-GTI
  • -Given: 38
Re: 3D rear badge
« Reply #5 on: March 09, 2011, 11:36:33 am »
Yeah MK4 black badge.
Havent actually fitted it to mine yet mate but my mate has done it to his mk5, will try and get a picture when I next see him next.
