Author Topic: Auto-locking central locking  (Read 10169 times)
Offline Mako V12V
    • Astons, Porsches & Golf GTIs
« on: March 08, 2011, 07:24:30 pm »
Is it possible to program the GTI to auto-lock the car with the central locking when you drive off?
I believe mini, bmw and others do this.
Cheers - Phil
VW Golf Edition 30, Candy White, 3dr Manual. Plus a stunning Aston Martin V12 Vantage!
Offline edd666999
  • -Receive: 89
Re: Auto-locking central locking
« Reply #1 on: March 08, 2011, 07:25:03 pm »
it can be coded by vcds, mine does it at 15mph i think
Offline Richn83
  • -Given: 49
  • -Receive: 85
« Reply #2 on: March 09, 2011, 08:56:52 am »
Yeah easy code with VCDS, you will also want to code the option to auto unlock with removal of the key from the ignition or you will be double pulling the handle every time you want to get out of the car.
Offline alexperkins
  • -Receive: 99
« Reply #3 on: March 09, 2011, 10:38:00 am »
If you have a highline dash, you can do it on there without vcds  :happy2:
Offline Mako V12V
« Reply #4 on: March 09, 2011, 12:40:05 pm »
Cheers people  :happy2:
Dont have highline though, so anyone with VCDS near Blackburn?
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #5 on: March 09, 2011, 02:34:49 pm »
Often thought about this   :confused: but do you think it would cause more wear to the door lock motors ? i.e locking every time car moves or like now  i only lock doors when parked ?.
Offline alexperkins
  • -Receive: 99
« Reply #6 on: March 09, 2011, 02:36:49 pm »
if it was gonna cause excessive wear, they wouldn't have made it an option.  :happy2:
Thats the main reason why the 6n2 polo didnt have it as it had pneumatic central locking, which to have auto lock would excessively run the pump possibly causing it to have a shorter life.
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #7 on: March 09, 2011, 03:04:25 pm »
........ok thanks :happy2:.If you want to say drop someone off would you need to stop the engine & remove key to let passenger door open ?. :smiley:
Offline alexperkins
  • -Receive: 99
« Reply #8 on: March 09, 2011, 03:07:47 pm »
The mk5 central locking works on the principle that, if the door is locked, you pull the handle once to unlock it then a second time to open the door.
You can either get people to double pull the handle to get out, or you can press the unlock button on the drivers door panel to unlock all doors  :smiley:
The padlock on the switch illuminates yellow when the doors are locked btw  :wink:
Either way, if its one door or all doors unlocked, itll relock at 10mph
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #9 on: March 10, 2011, 08:13:17 pm »
Thanks again for that. :happy2: So finally the autolock only comes on at a certain speed ? i.e if it's just ticking over it won't lock ?.
Offline alexperkins
  • -Receive: 99
« Reply #10 on: March 10, 2011, 08:45:55 pm »
aye 15km/h or about 10mph ;) At idle it wont lock by itself.
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #11 on: March 10, 2011, 11:19:11 pm »
........thanks Alex.Will get my mate to do it on saturday when he changes the brake fluid,he works for VW & i only have the midline comp in my ED30. :smiley:
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #12 on: March 13, 2011, 08:57:01 am »
Well it done yesterday along with the brake fluid change & '' yes'' great little feature. :happy2:
Offline alexperkins
  • -Receive: 99
« Reply #13 on: March 13, 2011, 08:57:37 am »
