Author Topic: How do I override DVD playback being disabled during driving on the RNS 510?  (Read 5533 times)
Offline xxx_mojo_xxx
  • MUBster DUBster
Putting aside safety considerations... is there a way to stop the DVD play back screen going blank when driving?
I'd like the missus and kids to be able to watch DVDs whilst I'm driving....
bear in mind its illegal for the driver to be able to see the screen in the dash whilst driving.
but its just a question of earthing it, when you lift your handbrake the connection to earth is made and it will work, permanently earth it and it will stay on, easy job  :happy2:
Offline 182_blue
  • -Receive: 54
^^you sure that works on the RNS510  :confused: , as i thought the unit was more clever than that and needed a special loom (here http://kufatec.com/index.php?main_page=product_info&cPath=5_10&products_id=382 ) to fool the car into letting you play stuff on the move
« Last Edit: February 27, 2009, 06:19:47 pm by 182_blue »
ah....i was thinking from an aftermarket point of view, could be different then, would have thought the principle was the same?
for the RNS i think it reads can bus signals regarding speed.  you will need to buy the kufatec adaptor.
i can confirm this works very well, it will work during driving. i have only tested this on a private test track though. i guess it would work on the highway, but i havent tested it.
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
^^^ Doesn't it screw up the navi's ability to sense speed when no GPS signal is available???
not in my experience but i could be wrong. i have rarely lost gps.
  • MUBster DUBster
235 Dollars!!!!  :scared:
What's the world coming to? Is there somewhere I can source this for cheaper....?
  • MUBster DUBster
Another thought...can't this be done thru VCDS?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
Nope
Offline cmdrfire
    • Commander Fire - my blog
/shrugs
Car electronics aren't cheap, there's generally a lot of work and testing gone into them, even (decent) aftermarket stuff. Kufatec does top stuff.
  • MUBster DUBster
/shrugs
Just to make sure before I take the plunge... installing the Kufatec thingy doesn't cause any other problems to the existing functionality of the SATNAV etc...
