Author Topic: Fitting Cat Back Milltek - Advice  (Read 3491 times)
Offline bodger00
  • -Receive: 20
  • A wish called Zonda
« on: March 09, 2011, 08:27:54 pm »
I have bought a cat back off someone on here (non res). I am really pleased with it . I can't wait to fit it but I need to know if I am missing any bits to get it to fit to my OEM system?
Are there any clips/reducers missing that I am going to need? If so do you know where I can get them from?
Offline big al
Re: Fitting Cat Back Milltek - Advice
« Reply #1 on: March 09, 2011, 08:33:24 pm »
Looks to me like it should fit ok without any problems, garage will probably stick a D shaped clamp on to hold them all in place.
Enjoy the noise!  :wink:
Offline bodger00
  • -Receive: 20
« Reply #2 on: March 09, 2011, 08:44:52 pm »
Cheers Al :happy2: Garage is me so I guess I can use the clamp that's already on the car.
Roll on the weekend :party:
Offline parks
  • Red ED30 No. 1778 Detailing World member
« Reply #3 on: March 09, 2011, 10:28:32 pm »
Do you have to cut the old one off?
Standard: Rear parking sensors, Parrot Bluetooth
Retro fitted: MFSW buttons, RCD510, Boot pop, Black Monza II, Xenons, Audi jacking points, open fog light grills.
Offline alexperkins
  • -Receive: 99
« Reply #4 on: March 09, 2011, 10:41:27 pm »
ooo shiny. Tempts me to get one  :signLOL:
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #5 on: March 09, 2011, 11:32:07 pm »
I'd order some high quality clamps like this:  :happy2:
http://www.ezt-autoteile.de/Auspuffanlagen/Schalldaempfer-Construct/Edelstahl-Spezial-Bandschelle/Powersprint-Construct-Edelstahl-Spezial-Bandschelle-%D8-68-mm-73-mm::32725.html
Maybe you need a reducer to fit the stock downpipe.
The Milltek catback will be the diameter of the Milltek downpipe.
http://www.ezt-autoteile.de/Auspuffanlagen/Schalldaempfer-Construct/Reduzierrohr:::11533_13301_13325.html
Just examples. Check the sizes by your self !!
"You get what you pay for."
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #6 on: March 10, 2011, 10:04:19 am »
.............as above,looks to me like the reducer clamp is missing(bit needed to fit milltek to the standard cat piece. Contact milltek & they will sell you one,not expensive. :wink:
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #7 on: March 10, 2011, 01:38:15 pm »
The outer diameter at the end of the sock downpipe/cat is 60 mm.
Just check the inner diameter of the Milltek. If there's tube insert
with 60.5 - 61 mm everything is fine and you just need a some
exhaust mounting paste (eg Holts).
Offline PDT
  • -Receive: 142
« Reply #8 on: March 10, 2011, 02:33:59 pm »
I have a load of spare milltek reducers for the nk5 here, can have one for the cost of postage :)
Offline the bruce
  • -Given: 322
  • -Receive: 100
    • my GTI
« Reply #9 on: March 10, 2011, 03:10:58 pm »
Very friendly offer !!
Offline bodger00
  • -Receive: 20
« Reply #10 on: March 10, 2011, 08:10:11 pm »
Thanks all for the replies! :notworthy:
There was some daylight left when I got home today so jacked up the car, put it on axle stands and had a look. After measuring the internal diameter of the miltek approx 69mm I definatley need 1 clip and 1 reducer of some sort. I am not sure of the dimensions but I guess they are standard. If I can't use the original clip then I guess I will need two clips and a reducer :rolleye:
@PDT I have sent you a PM :happy2:
